PeteHZ Posted March 16, 2020 Share Posted March 16, 2020 Hi all, can someone please tell me what product options this ute has. Cheers Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 16, 2020 Share Posted March 16, 2020 8N80TJZ796053Z 8 - Holden Australia N - Kingswood 80 - Ute T - 308 J - 1979 Z7 - NZ Assy Plant 96053 - Serial Number Z - HZ 3 Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 16, 2020 Share Posted March 16, 2020 L31 = 308 (standard compression) M41 = Turbo-Hydra-Matic 400 three speed column or console shift auto. Replaced in May 1979 by Turbo-Hydra-Matic 350 G80 = LSD G73 = Heavy Duty/10 Bolt Diff 2 Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 16, 2020 Share Posted March 16, 2020 That's just from a quick google search, the diff codes I'm not completely 100% on but everything else should be pretty accurate unless the internet is lying. Quote Link to comment Share on other sites More sharing options...
PeteHZ Posted March 16, 2020 Author Share Posted March 16, 2020 Thanks for that, so I take T is for a original V8, I'm looking at buying this ute, it has a twin headlight front too would this be period correct? Just asking as it has LVVTA cert plate, not the original plate Quote Link to comment Share on other sites More sharing options...
PeteHZ Posted March 16, 2020 Author Share Posted March 16, 2020 12 minutes ago, kyteler said: L31 = 308 (standard compression) M41 = Turbo-Hydra-Matic 400 three speed column or console shift auto. Replaced in May 1979 by Turbo-Hydra-Matic 350 G80 = LSD G73 = Heavy Duty/10 Bolt Diff Perfect thanks Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 16, 2020 Share Posted March 16, 2020 I think the twin fronts were only on GTS, Premiers, Statesman and Sandmans but I can't be sure on that. With that said though, easy enough to swap a nose, etc. and I guess it would potentially be possible to have been optioned with it given the range of other models that had it. Quote Link to comment Share on other sites More sharing options...
PeteHZ Posted March 16, 2020 Author Share Posted March 16, 2020 5 minutes ago, kyteler said: I think the twin fronts were only on GTS, Premiers, Statesman and Sandmans but I can't be sure on that. With that said though, easy enough to swap a nose, etc. and I guess it would potentially be possible to have been optioned with it given the range of other models that had it. Thank's for all your help, would you know where the best place to buy new panels like a front nose cone etc? Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 16, 2020 Share Posted March 16, 2020 No idea sorry. Rare Spares, maybe? I'm not sure if anyone does repro HZ stuff. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted March 16, 2020 Share Posted March 16, 2020 https://www.kingswoodcountry.com.au for parts oldholden.com for info 1 Quote Link to comment Share on other sites More sharing options...
PeteHZ Posted March 19, 2020 Author Share Posted March 19, 2020 On 16/03/2020 at 21:42, AllTorque said: https://www.kingswoodcountry.com.au for parts oldholden.com for info Thanks Quote Link to comment Share on other sites More sharing options...
