ProZac Posted January 19, 2020 Author Share Posted January 19, 2020 The loving projects is mutual mate :-). The black stuff was ABS, Imagin brand. Prusa i3 MK3s, generic ABS temp settings, no tweaking. It warps a bunch on larger prints though, as not a heated build chamber. Mostly I print PLA on it though, and get awesome results also. RS Components branded stuff, just for prototyping :-). 1 Quote Link to comment Share on other sites More sharing options...
Valiant Posted January 31, 2020 Share Posted January 31, 2020 What gearbox are you going to use? I had trouble with the turbo, wide block, hydraulic clutch vs cable clutch ute when I did mine. Quote Link to comment Share on other sites More sharing options...
ProZac Posted January 31, 2020 Author Share Posted January 31, 2020 I've got a box from a 2.6 2nd gen L200, so wideblock and cable, should bolt to everything / existing mounts and be the right length. I've got a spare Starion box too, so might look at swapping the gearsets if the Starion boxes have longer legs, no idea if they're even any different. 1 Quote Link to comment Share on other sites More sharing options...
Valiant Posted January 31, 2020 Share Posted January 31, 2020 Sorted. Quote Link to comment Share on other sites More sharing options...
