Kiwibirdman Posted October 14, 2019 Share Posted October 14, 2019 I have bought a VN commodore wiper motor to put in the EJ. I also have an EH 2 speed wiper switch, so far so good. Where I need help is sorting out the wiring. Green = high speed Red = low speed Black = earth Brown = Ignition Yellow = Park I understand to make the motor work on low speed it need power to red and earth to black. High speed = Green and black, easy enough. To get the park to work it needs power to Brown (which can be live anytime the ignition is on) and yellow and red looped together. The circuit between red and yellow is broken when the motor is in operation. Is this correct and does anyone have a simple wiring solution to make this work with a simple 2 pole switch. Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted October 14, 2019 Share Posted October 14, 2019 won't the VN have a wiper relay to control the park and intermittent delay ? you may need one to get the electrickery to work ? 1 Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted October 14, 2019 Author Share Posted October 14, 2019 A relay or 2 are probably going to be needed. Hoping some smart bugger already had the answer. 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted October 14, 2019 Share Posted October 14, 2019 I've done a quick doodle, you could potientally get away with one relay but you'd need to test the wiper motor to check something. Pm Incoming 1 Quote Link to comment Share on other sites More sharing options...
