A Poor Mans Defender.... SIIA 109
nzstato
  • Replies 78
1 minute ago, SOHC said:
Man the urge for me to get a landrover is getting stronger
Is that a come-along winch on the front?
Do it... place this came from had a paddock full of em
no idea, it’s got a ratchet at the back so basically same design you’d see on s boat trailer
8 hours ago, Indiana_Jones said:
What other toys have they got? \link
Model A fords, late model falcons, S1 land rovers...
LR pricing seems two phased - either decent projects for a few k or stuff that has been barely tidied up for a WOF which is priced for moonbeams....
1 hour ago, KP_wag said:
So awesome, and loving the snorkel - you should swap the top for a copper downpipe elbow for max future patina. How does she handle highway speeds?
That's an idea...
Like you'd expect, a twitchy brick.  But based on my experience from my previous one I know that can be improved.  Just committed to not taking a spanner to it until this mini is finished...
2 minutes ago, Nominal said:
Got spiders?
I doubt that a swap to a Toyota or Nissan chassis will fly as mod-prod. The example in the sheet you linked if for an in-brand swap.
See here for example
http://lvvta.proboards.com/thread/541/modified-scratch-built-chassis
Hmmm so that means I'm committed to a range rover chassis if I go down that path... with all the mechanical goodnesss
  • Sad 1
My next project is going to be a series 2 or 3 swb on a discovery chassis, discovery is 100" wheel base so will need to be cut down. I already have the discovery and the land rover 24 spline is plenty strong enough for the power it will have.
Why do you want to go to a ifs chassis or will you change it to a solid axle?
Go fo Disco as a donor, like this one (not sure if its had the chassis swapped or just the running gear)
https://bringatrailer.com/2015/04/08/impressive-build-v8-swapped-1967-land-rover-109-series-2a/
I have the “when a 4x4 is born’ DVDs where a guy does exactly this.
Would stay solid axle but wanted to get coils/disc brakes/power steer/modern power train in one hit rather than make up piecemeal
Disco chassis is 100” wheelbase so would need to be lengthened
Was trying to stay away from 200/300TDI as most stuff for sale is well worn and will need rebuilt.
thinking either rebuild the running gear I have in it now (if parts are even available) or complete engine/gearbox swap to something which has the output shafts in the corect orientation.
Options?
Thats still the original series chassis and diffs on leaf springs, it just has the engine and trans from a disco
I assumed they had swapped the mounts on the disco axles based on that article but maybe not?
I’m sure Himalaya had a write up on it that I read awhile ago but I can’t find it now.
The axles I have are essentially the early version of what ended up in the defender/disco.  It means a disc brake conversion can use existing LR parts.
