Removal of Sunroof Hole
Coyster
I'm currently rebuilding an HQ Monaro Coupe, it is at the panelbeating stage and I'm wondering whether or not I should get the sunroof hole removed from the roof. Someone put it in back in the 80's before I bought it and while I'm nervous about getting it done, as it needs to be done properly, and I don't really have the extra cash to spend, I don't want to regret not getting it done when the build is complete.
Can anyone recommend someone who specialises in doing this kind of work and knows they do a good job? I'm in the Auckland area.
thanks!
TBH I think sunroofs (sunrooves?:scratch:) are friggen sweet period correct mods, and wouldn't really detract from the car at all rather add to its "rad"ness.
Its a pretty time consuming thing to do, and needs to be done right, by someone who knows knows how to fab, you might get away with a roof cut from a sedan and take out the section you need, but if its not welded right, its warp central..
I would call Chopper at Choppers auto body restorations in Kumeu, he pumps out some quality resto and fab work.
take it out. you'll regret it later if you don't.
especially when it starts leaking and you can't buy any bits for it.
patching a sunroof isn't as hard as people make out, anyone with decent panel skills should be able to sort it.
i know a guy but hes eye wateringly expensive. hes very good, i guess that's why hes so spendy.
if you get stuck PM me.
  • Like 6
Find a panel better with a reputation for metal finishing.
We have done a couple roofs at work. Is a very time-consuming exercise between wheeling up a patch panel/welding/and dressing the roof up.
There is a good couple hrs in welding as you can only weld 20mm ish before stopping and hammering the weld area.
Will pretty much always need a fine skim coat of filler but when done properly Wil need very little product .
Worth it though. Old aftermarket sunroofs are crap/always leak. And detract from total value of the car
  • Like 6
