Sign in to follow this
rusty360
Fault codes - help
Hi all looking at a new daily, got it checked out and when guy did diagnostic scan these came up. Normal scan no faults. Drives great, did have the battery fail recently so that explains that one, linked I'm thinking/hoping?
Share this post
Link to post
Clear codes, drive car for a bit, see if they return. Not sure on the first code, but yeah the second looks like it'd be the battery.
Share this post
Link to post
I'd be weary of that transmission one as those Mazdas do give trans trouble.
Share this post
Link to post
Yeah, brother-in-law just had the trans control unit replaced on an early Mazda 3, gave a similar code, occasionally wouldn't change up from 3rd, but would run normally after stopping.  Took a while for the problem to get frequent enough for him to note the circumstances/pattern to describe it to the Mazda workshop.
Share this post
Link to post
Was it scary expensive?
Share this post
Link to post
Could take it to a Mazda garage and have them scan it / give you estimates perhaps. Dealership might get more detailed info from the ECU. I know when I had my van scanned yonks ago (not Mazda) they could tell exact details of the fault, when it happened and all that jazz. From the fault code they knew the part that had failed/ was intermittently failing.
Share this post
Link to post
Just bail on it, don't need to mess with no 10 year old car throwing codes. Unless the code is a feature and you are getting it cheap because of something you know how to fix.
Share this post
Link to post
Probably. Iirc, it was tucked away down on the gearbox and they had to remove some the engine plumbing to get to it.
Share this post
Link to post
Have spoken to mazda they said they will get the same codes if they are there.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
