SOHC Posted September 30, 2019 Author Share Posted September 30, 2019 Tank decals for sale on line had a ruler for size witch makes it easier for copying 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 30, 2019 Author Share Posted September 30, 2019 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 30, 2019 Author Share Posted September 30, 2019 5 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 2, 2019 Author Share Posted October 2, 2019 Suzuki all ways made the most strange little muffler things for the MX and trail bikes, I found this stainless steel thing, I will pack some scotch brights inside, 3 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 3, 2019 Author Share Posted October 3, 2019 Muffler is finished, I think it was ballcock from a toilet. 7 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 3, 2019 Author Share Posted October 3, 2019 I ended up drilling twice as meany holes in the muffler core before welding it in, 7 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 4, 2019 Author Share Posted October 4, 2019 The worn out sprocket carrier spigot on the rear wheel was fixed by a friend, he made everything true in the big lathe at his work and fitted a bronze bush. 4 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 5, 2019 Author Share Posted October 5, 2019 Forks had one small patch where the hard chrome had worn off and was rust pitted, I got some stuff like JB weld and covered the bad patch, I don’t know how well this will work, I really need to find some new fork stanchions 1 Quote Link to comment Share on other sites More sharing options...
xsinclairx Posted October 5, 2019 Share Posted October 5, 2019 52 minutes ago, SOHC said: I really need to find some new fork stanchions What size are yours? If they're 30mm tf125 ones should work. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 5, 2019 Author Share Posted October 5, 2019 6 minutes ago, xsinclairx said: What size are yours? If they're 30mm tf125 ones should work. They are 34mm x 600 mm long Suzuki only used 34 mm on a few bikes, Yamaha used 34mm in meany bikes for meany years 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 6, 2019 Author Share Posted October 6, 2019 I got a Suzuki TM folding MX Kickstarter, this is needed to clear the expansion chamber and also the TS dose not fold away at all just the top peddle part. I also got the needle roller bearing for the shift drum, only 2 bearings had to be genuine Suzuki in the motor. 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 9, 2019 Author Share Posted October 9, 2019 LH inner side cover was all smashed up with 3 chunks missing and the lower sprocket cover tab was missing, I gas welded it up, proper fusion welding not low temperature brazing. 4 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 10, 2019 Author Share Posted October 10, 2019 Still waiting on that LH main bearing and seals, they sed 2 weeks but it has been like a month now, if those parts turn up I can put the motor together. had to repair the front brake plate with my new found skill. 6 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 13, 2019 Author Share Posted October 13, 2019 Got the yokes and forks on, having trouble finding rear shocks, they are 340mm eye to eye and 55mm wide if anyone has an idea what would be that length? TF shocks were too spindly and light. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 16, 2019 Author Share Posted October 16, 2019 Started painting engine parts, I am going with a black engine, with VHT paint you never know what’s going to come out of the can, it sed mat but it’s gloss, brakes rebuilt, surprisingly the shoes are still good 3 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted October 16, 2019 Share Posted October 16, 2019 I had no idea you could gad weld aluminium. That was rather epic. 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 16, 2019 Author Share Posted October 16, 2019 45 minutes ago, flyingbrick said: I had no idea you could gad weld aluminium. That was rather epic. The trick is to agitate, 2 Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 16, 2019 Share Posted October 16, 2019 Cold there? I'm finding with vht high temp and CRC satin black it they both come out glossy and take forever to dry on cold and humid days. Warm dry days they are mint and matt/satin like normal. 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 17, 2019 Author Share Posted October 17, 2019 18 hours ago, Raizer said: Cold there? I'm finding with vht high temp and CRC satin black it they both come out glossy and take forever to dry on cold and humid days. Warm dry days they are mint and matt/satin like normal. I heated the parts so the paint dried very fast and I baked it a bit once it was on, 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 18, 2019 Author Share Posted October 18, 2019 The kickstarter lever is from a TM 400 and dose not clear the clutch cover fuck it, someone sed DR400 1980 to 84 lever will fit but it dose not have the pinch bolt on the spline. My engine has the early big spline shaft otherwise I could shove on anything. Quote Link to comment Share on other sites More sharing options...
