rusty360 Posted July 18, 2019 Share Posted July 18, 2019 Hi all, I'm finally going to install the electronic dizzy I brought for my EH wagon. I've got to bypass the ballast resistor wiring so the new dizzy sees 12v all the time. But I'm not sure what type of coil to buy? Is the old one doesnt sound like it will be up to the job. How many ohms do I need? Cheers rusty Quote Link to comment Share on other sites More sharing options...
Valiant Posted July 18, 2019 Share Posted July 18, 2019 Three 0hms. That's what you need. 1 Quote Link to comment Share on other sites More sharing options...
rusty360 Posted July 18, 2019 Author Share Posted July 18, 2019 I thought 3 ohms was a points coil? Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted July 18, 2019 Share Posted July 18, 2019 1.5 Ohms was for points with ballast wasn't it? Quote Link to comment Share on other sites More sharing options...
rusty360 Posted July 19, 2019 Author Share Posted July 19, 2019 22 hours ago, Valiant said: Three 0hms. That's what you need. Yeap you are right a 3 ohm is the go. Cheers! 1 Quote Link to comment Share on other sites More sharing options...
Valiant Posted July 19, 2019 Share Posted July 19, 2019 Any time. Quote Link to comment Share on other sites More sharing options...
rusty360 Posted July 19, 2019 Author Share Posted July 19, 2019 Ive actually just worked out I need a 0.5 ohm coil. the dizzy has a built in HEI unit. humm off to google i go. 1 Quote Link to comment Share on other sites More sharing options...
sr2 Posted July 23, 2019 Share Posted July 23, 2019 Is it an aftermarket dizzy or one from a VB - VK Commodore? Quote Link to comment Share on other sites More sharing options...
rusty360 Posted July 25, 2019 Author Share Posted July 25, 2019 On 23/07/2019 at 21:56, sr2 said: Is it an aftermarket dizzy or one from a VB - VK Commodore? After market based on a holden VB - VK one Quote Link to comment Share on other sites More sharing options...
cletus Posted July 25, 2019 Share Posted July 25, 2019 Dunno if it's the right ohms But I've always had good results with msd blaster coils 1 Quote Link to comment Share on other sites More sharing options...
Esky_addict Posted August 9, 2019 Share Posted August 9, 2019 I put a msd dizzy in my holden, not sure if EH are wired the same but I just ran a wire from the back of an accessory fuse to the coil for when it's running and kept the original ballast wire hooked up to power coil while cranking. I used a msd blaster aswell but any non ballast coil should be sweet. 1 Quote Link to comment Share on other sites More sharing options...
