Snoozin Posted May 20, 2024 Author Posted May 20, 2024 I've put some brand new Tein Mono Sport dampers in, tweaked the ride height and it's back on my fav set of wheels for now. Waiting in the ceiling is a lip, wing and carbon mirrors from Mode Parfume/Exceed that I just need to sack up and get painted/attach to the car. I note I also have a small oil leak from somewhere that I'll need to find, but I am getting a little keen on pulling the engine out for a rings and bearings refresh/clean everything up all spiffy like. 1 Quote
mjrstar Posted May 20, 2024 Posted May 20, 2024 Looks great! Whats the reasoning behind planning a strip down.. Is it down on compression, or smokey? I found the stock breather system lends itself to putting quite a bit of oil into the inlet manifold when at high revs with the throttle closed. Quote
Snoozin Posted May 20, 2024 Author Posted May 20, 2024 Uses a little oil, and occasional smoke but nothing serious (for a B series anyway). Just keen on getting everything as close as I can to minty spec/I'm bored and currently have no car projects as such. Quote
mjrstar Posted May 20, 2024 Posted May 20, 2024 Oh man, I'd be putting the stock b series aside and sliding a nicely fettled b20 vtec, with a b18 engine tag on it back in there.. the engine tags cut off pretty easily (to make your b20 magically into a b16 or b18)with some patient hacksawing.. well apparently Quote
Snoozin Posted May 21, 2024 Author Posted May 21, 2024 Haha nah nah this car's destiny is to remain fairly close to stock with a suite of period-spec bolt on bits. More concours than racecourse. Quote
RUNAMUCK Posted May 21, 2024 Posted May 21, 2024 Cummon Ritchie, You know you want to fit three spoon engines with MoTec exausts....... Quote
Honda Ass Dragger Posted May 21, 2024 Posted May 21, 2024 57 minutes ago, mjrstar said: Oh man, I'd be putting the stock b series aside and sliding a nicely fettled b20 vtec, with a b18 engine tag on it back in there.. the engine tags cut off pretty easily (to make your b20 magically into a b16 or b18)with some patient hacksawing.. well apparently I have often though about doing B20 before I went Turbo I got put off by cylinder wall cracking and for the effort involved a well built b18 will make nearly as much jam Quote
mjrstar Posted May 21, 2024 Posted May 21, 2024 19 minutes ago, Honda Ass Dragger said: I have often though about doing B20 before I went Turbo I got put off by cylinder wall cracking and for the effort involved a well built b18 will make nearly as much jam Yeah if you aren't going crazy then stock block is OK, you need to put another 4 grand aside for a set of darton sleeves if you want to go wild.. and then youd net far better results with forced induction... that's the downside of most na engine builds, the turbo option is just so much easier to make reliable power. Stock b18cr go alright with a gearset, but not going to set the world on fire. Quote
Honda Ass Dragger Posted May 21, 2024 Posted May 21, 2024 I'm looking forward to L15B becoming cheaper and more affordable - as I suspect they will become a great swap option once ecu tech catches up Quote
Snoozin Posted May 21, 2024 Author Posted May 21, 2024 7 hours ago, mjrstar said: Yeah if you aren't going crazy then stock block is OK, you need to put another 4 grand aside for a set of darton sleeves if you want to go wild.. and then youd net far better results with forced induction... that's the downside of most na engine builds, the turbo option is just so much easier to make reliable power. Stock b18cr go alright with a gearset, but not going to set the world on fire. No one's building any flash engines for this car, it's perfect the way it is. Quote
kws Posted May 21, 2024 Posted May 21, 2024 Not gonna lie, I adored (and regret selling) my B18CR ITR with a turbo kit on it. That thing was awesome to drive, shame I was too young to respect it and got rid of it before I died in it. 1 Quote
Popular Post Snoozin Posted August 24 Author Popular Post Posted August 24 Well, I have sold this car and the new owner is picking it up on Saturday. These are the last photos of it, after raising it to legal ride height, fitting the RGs, and road testing some recent work on it thanks to assistance from Brad/dellorto (cambelt, waterpump, front main, cam seals, Mugen engine mounts, CV inner boots, sump gasket, PCV O-ring, oil cooler O-ring, fresh MTF, oil and filter). Good to go! It's garage space will be filled with a GR Yaris turbonugget. I might do a thread I dunno, it's probably not overly interesting. 20 4 1 Quote
