Sign in to follow this
kiwi808
Tortron’s ‘62 Moggy oil leaks and electrical issues discussion thread.
I am fortunate for several reasons
1. I have free, endless access to coffee
2. The man at the steel shop immediately felt sorry for me when hearing what I was building and threw in several extra meters of steel
3. I have a half decent minor to take measurements from
Share this post
Link to post
                                                          Bruh.
  • Haha 3
Share this post
Link to post
I don't know much about the commercial chassis's I'm afraid Rus.
After this I will be fully set up to replace sedan chassis legs, fairly quickly. So tell your friends
Share this post
Link to post
It probably is good to keep that information secret so there's less people capable of keeping these things on the road.
The greater good.
Keep calm and minor repairs.
  • Haha 3
Share this post
Link to post
Designed for a boxer 4 so wide and short
65 cm between the lever arm bodies
About 52 cm from crossmember to radiator panel
About 41cm between the chassis rails
More or less as tall as you like.
Generally you have to cut out the crossmember to fit anything decent. Also the steering rack is directly below that. So that's in the way of most gearbox bell housings.
Tube front ends seem common enough
Share this post
Link to post
Not much cutting to get this in - just a RHS front crossmember under the radiator.
Share this post
Link to post
Absolute skullduggeryIMG_20190524_150011.thumb.jpg.163fe769c7fd68af26f92a228d592ce6.jpg
9MUH engine tag on a block with an upright oil filter at the back
Share this post
Link to post
3 minutes ago, Nominal said:
Lol, it would take a real barry to notice that.
Share this post
Link to post
My great-uncle bought it like that from the dealer mayte.
Must have been short of the right engine at the factory and grabbed another one that was lying around.
Share this post
Link to post
Its just had an oil filter relocation kit put on it :wink:
The real question is why bother changing the number. They get removed when you skim the head anyway
Share this post
Link to post
That's a point. Not sure that any of the seven BMC cars I've owned over the years still had engine numbers.
Share this post
Link to post
Both the 1098 in mine, and the spare I have, are still sporting their 10MA tags.
Share this post
Link to post
On 24/05/2019 at 17:05, tortron said:
I'll probably remove it and restamp with an appropriate/funny one
13b?
Share this post
Link to post
