Tortron’s ‘62 Moggy oil leaks and electrical issues discussion thread.
kiwi808
I am fortunate for several reasons
1. I have free, endless access to coffee
2. The man at the steel shop immediately felt sorry for me when hearing what I was building and threw in several extra meters of steel
3. I have a half decent minor to take measurements from
  • Like 6
Designed for a boxer 4 so wide and short
65 cm between the lever arm bodies
About 52 cm from crossmember to radiator panel
About 41cm between the chassis rails
More or less as tall as you like.
Generally you have to cut out the crossmember to fit anything decent. Also the steering rack is directly below that. So that's in the way of most gearbox bell housings.
Tube front ends seem common enough
