Sign in to follow this
RUNAMUCK
Best thing to clean out a fuel tank?
What's the best stuff to use to clean out a fuel tank? It's not rusty, but there's rather a lot of crusty varnish inside it.
Share this post
Link to post
Put a hand full of gravel or two in it, a bit of water, and shake it.
Share this post
Link to post
...or perhaps a length of chain? Might be easier to get back out again.
Share this post
Link to post
I've rigged bike tanks to a tumbler with a box of 3/16" square brass nuts inside. Worked well
Have heard of people strapping car tanks to concrete mixers.
Share this post
Link to post
Speed up the process eleventeen billion percent by strapping it to a car wheel instead!
I'll just let myself out.--->
Share this post
Link to post
I've tumbled things strapped to a car wheel before, let it idle for an hour on stands.  Don't recommend it.
Share this post
Link to post
If it's not rust, then why not swill around some fresh petrol? Or thinners?
Share this post
Link to post
I recently did this on a tank that was pretty rusty and the difference was literally day and night.
Simple process, pop down to bunnings and get yourself some hydrochloric acid (or if you've got a mate whos a concrete guy they will have barrels which I am sure you can poach some off)
Bang in some water. I did about a 30/70 mix (Acid 70) and put in the acid.. It's dangerous shit so make sure you're wearing minimum gloves, face mask and goggles.. Nasty shit if you get it in your eyes.
Let it sit for approx an hour, turn on the side, again on the side etc etc..
Once thats done, drain the solution.
Fill the tank back up nearly full to the top with water and add some baking soda, table spoon by table spoon until the water stops fizzing when you put it in. Shake said water around, repeat the last step
Empty and you're away laughing.
I did have little bits of rust floating around the tank afterwards which was a pig to get out but I just lopped off a piece of garden hose and jimmied up an attachment to the vacuum cleaner and sucked out the rusty particles.
Not sure if this is the proper way or not but it worked for me haha
E: Water before acid, always! As I said, twice.. it's nasty stuff
Share this post
Link to post
I've got acid in.my "DG" cupboard.
But it's not rusty. The inside of the tank looks to be zinc protected. So if I fizz it with acid I'll. Be removing that factory rust proofing.
Share this post
Link to post
The rocks or chain would probably knock it up a bit too
Share this post
Link to post
Have you considered another fuel tank that is not fucked?  This is what I did with the last car I had with a crusty tank..
Share this post
Link to post
The only tank option I found was ex the states (assuming this is barts middies crx) when I went through my tank bullshit.
I say try slosh fresh fuel through it and see how it goes
Share this post
Link to post
It's not fucked by any stretch.
It just has varnish scale build up in a few places.   the chain trick should work.
I might get Mr Karcher to stick his nose in there too.
Share this post
Link to post
Anything like a chain will probably bugger the zinc coating.
Like dissolves like, so you'd think a solvent like petrol would dissolve the varnish from evaporated petrol? (+ injector cleaner..)
edit, internet reckons ethanol will do it better
also e85 circulating through the tank for a few  hours appears to clean it
Share this post
Link to post
What I don't want is new gas to dislodge the scale and have it block up the filter sock on the new pump.
I've used stones before on a motor bike tank.
Share this post
Link to post
