ThePog implements balance on the Dynafari
How the hell did they get the silver / black top names if the silver or black top is meaningless? Sounds like the whole designation is meaningless tbh, and it's nothing more than a construct of Barry's who like to sound like they know what they're talking about
Link to post
  • Replies 606
This is serious stuff in patrol 4x4, don't belittle it;
JFF45 Import Safari are a special mix of components.
For Australia we have
Silvertop 8/87 to 7/95 Valve recessed pistons 28mm pin 950 grams piston and pins. Regardless of rocker cover colour.
25mm camshaft followers, Vac pump on alternator. Short squirters. Rear oil seal press in 86mm.
6 bolt crankshaft 61mm PCD, 58mm front oil seal. 18mm long oil pump gears.
Blacktop 8/95 to 5/96 flat top pistons 28mm pin 1070 grams piston and pins.
26mm camshaft followers, Vac pump on alternator. Short squirters. Rear oil seal press in 86mm.
Blacktop 6/96 to 9/97 flat top pistons 30mm pin 960 grams piston and pins.
26mm camshaft followers, Vac pump under IP. Short squirters. Rear oil seal press in 86mm.
GU N/A 10/97 to 11/2002 flat top pistons 30mm pin 960 grams piston and pins.
26mm camshaft followers, Vac pump under IP. Short squirters. Rear oil seal Unitised 86mm.
6 bolt crankshaft 62mm PCD, 58mm front oil seal. 18mm long oil pump gears.
GU Turbo 02/99 to 7/2007 flat top pistons oil gallery cooled piston 1150 grams piston and pins.
26mm camshaft followers, Vac pump under IP. Long tube squirters. Rear oil seal Unitised 96mm.
7 bolt crankshaft 72mm PCD, 60mm front oil seal. 21mm long oil pump gears.
The change to the vac pump is very difficult to confirm seems there is lots of conflicting data even in the manuals of AUS supply.
The 25mm camshaft follower has a very different camshaft fitted to the silvertop. It is quite different to the camshafts fitted after the actual silvertop model. This has quite a bearing on why the turboed silvertop produces torque and power differently from all models after. Also added to this the head for the actual silvertop is different for the black top even the 28mm pin blacktop it also has different precomb which have a slightly smaller chamber volume and shape.
I can confirm this outright it seems all 26mm followers camshafts are the same timing and profile right through to the T model engine. But there is 5 part numbers for the TD42 engine world wide, which is interesting.
Link to post
On 12/03/2021 at 20:15, ThePog said:
Ah I maybe should have been clearer, both types came with both colours of tappet colour....
And @yoeddynz, that means you need to strip it and measure gudgeons to be really sure....
Fuck that.
I'll find out what it is one day when it sends a rod through the case after I try to pass a nissan tiida (insert any other typically slowly driven modern car) on a slight downhill using gravity to aid punching the Bedford beyond its normal safe working speed.
  • Haha 1
Link to post
17 hours ago, kyteler said:
https://debossgarage.com/ics2021
I think you should enter this monsoir pawg.
I had a look though some of the entries, I am quite gratified you think it's interesting enough to compete. I don't know how well it would do against some of those no rules american builds though.
Link to post
You get to choose your categories to compete in, definitely a worthy candidate in my mind.
Link to post
Yep well worthy of an entry - skid factory will love it cos safari and surely there is some worthy bracketry  - tis a very cool well executed clean looking conversion
Link to post
Shit that is some vinyl wrap, a trip to repco and finding one of the dozen or so tuff rangers on literally any street in NZ to put up on blocks.
I will see what I can do... cheers all.
Link to post
1 hour ago, Mof said:
Suggest lose that dodgy lightweight loop on the rear and put on one of these http://www.jost.nz/fileadmin/user_upload/jostnz.co.nz/pdf/bpcph20wmk.pdf
That loop is OG factory goodness, so yes I'll probably replace it at some stage....
I have been thinking about converting the towbar to a socket type, as well as modding the front bar the same. That way I could potentially mount a winch front or back as needed.
It might be overkill.
Link to post
  • ThePog changed the title to ThePog implements balance on the Dynafari
