Sign in to follow this
shizzl
shock insert rebuild
have any of you fine folk tried to rebuild a shock insert?
come across this video on youtube of some barry changing the oil in one..
the front shocks in the hunter are totally naffed, its leaning to one side and rolls like a pig..
cant source new inserts from anyone so this could be a cheap option to try..
I have a pair of spare struts to piss around with so ill have a crack on those, if it fails and I burn the shed down, then ill try the Peugeot 106 insert conversion.
if it does actually work then I will rebuild the shocks that are in the car and fit a coilover kit..
thought this could be usefull for some of you with old junk like mine.
Share this post
Link to post
good in theory, but use heavy grease on drill bit to avoid ingress of swarf,
weld a threaded insert on there so you can change the oil grade if to soft/ stiff
Share this post
Link to post
ive rung so many shock shops this week trying to source some new inserts...
their response everytime is " ok, ive got the measurements and vehicle details from you, ill call you back in about 30mins"...
5 days later, no fucking reply... I hate dealing with parts people, theyr useless
Share this post
Link to post
yeah bloody expensive though and Ill need to freight my uprights to him for "modification" then freight them back
Share this post
Link to post
@idealneil........ Techneil in CHCH. does real rebuilds up to WRC spec.
after the limited contact with Chris at Suspensiontech i wouldn't waste my time with thim
Share this post
Link to post
My brother had a bastard of a time with the products from suspensiontech "this is the spring/shock combo you want. It won't bind or anything." - bound like a bastard.
Share this post
Link to post
i wanted a price for 350mm long, 180lb/in coilover springs and Bilstein inserts. Chris was adamant i needed to send the entire unit up for him to measure and fit, then charge a 're-valvling fee for an off the shelf part.
have also heard some of his rebuild parts are not the real deal, but merely a knock-off
Share this post
Link to post
hence the reason Im not prepared to send my struts up.. I just want a bloody insert that will fit in the tube and fit the top hat..
seriously why are parts monkeys so reliant on computers and shit these days.. we used to run off 2" thick parts books and match up off diagrams and measurements.
thats all I want
Share this post
Link to post
TBH you might have the best luck at repco.
I've gone into BNT with parts of unknown origin and they don't even want to take a look in their stock.
The young guys at repco are usually good at just digging through parts to match stuff up
Share this post
Link to post
Probably online listings somewhere. I can't remember the model of Peugeot shocks I used but they have been ok at factory height.
Share this post
Link to post
I remember being able to search through online sizing back in the day, seems no one has stuff listed like that now..
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
