Mr.Mk1
Mr.Mk1s Escort
Well I’m fucked if I can find the original discussion thread, if anyone can that would be sick but I’ve been looking for way longer than I should have.
Share this post
Link to post
36 minutes ago, BobbyBreeze said:
Still planning CA Josh? So keen to see how you get on!
p.s. forced induction is best!
I agree.
Share this post
Link to post
Absolutely CA18DET still. I’ve been collecting bits and pieces as they come up, check trademe favourites every day.
Share this post
Link to post
I get excited with the idea of you working on this mate..its been agers  and seeing what you did with the old datto.... its gonna be good..
And yeah the ca18 looks better straight and not on the piss
Share this post
Link to post
Great idea mate..
I was wanting to replace 2 sections on my chassis rails...citing them off and straightening them didn't cross my mind.
Share this post
Link to post
psssst. I have 280mm rotors and 4 pots...... Fail that I want to say non turbo stagea or some other big body nissan have a 280 4 stud disc and 2 pot caliper. twin piston on same side so will help for wheel clearance. SHuld be bolt on with those s13 uprights
Share this post
Link to post
I know I know, but I want to run wide 14s and the cool brakes won’t clear.
don put me onto the RB25 powered 280 & 2pots and I’m pursuing..
heres an upright CA for interests sake
Share this post
Link to post
What hubs are you running?  Sorry if you've already said but I missed it.
Are s13 discs and calipers an option? I'm sure 14's clear them and with decent pads they're a very capable brake set up.
Share this post
Link to post
The hubs are S13 4 stud. The s13 disc (254mm) and calipers (single pot) are decent but they HP vs size bracket I’m aiming to be In Requires 2pots and 280mm vented.
would be perfect for an NA setup.
Share this post
Link to post
I'm sure there's others, but vg30 2wd D21 navara have a two pot caliper. Both pots at the rear side, so they don't prevent the use of fully hektik negative offset wheels.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
