yoeddynz Posted November 3, 2018 Share Posted November 3, 2018 I agree. Enjoy this part where things are free/just time. Please dont be drawn over the tracks to the wrong side with this car. Keep it oldschool. Similar warning I had to give Mason when he started to veer off track and things were approaching this.... 3 2 Quote Link to comment Share on other sites More sharing options...
rotorhoe Posted November 5, 2018 Share Posted November 5, 2018 Hmmm almost, but more this 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 5, 2018 Share Posted November 5, 2018 Oh classy. Just what I'd expect. Quote Link to comment Share on other sites More sharing options...
rotorhoe Posted November 5, 2018 Share Posted November 5, 2018 which brings me to introduce the final piece of art, "Rom3yz zhit xox": 4 1 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted November 6, 2018 Share Posted November 6, 2018 I liked the part where you said this car is getting a powerglide and a transbrake 1 Quote Link to comment Share on other sites More sharing options...
Popular Post rotorhoe Posted November 6, 2018 Popular Post Share Posted November 6, 2018 12 minutes ago, Testament said: I liked the part where you said this car is getting a powerglide and a transbrake You mean these? 8 2 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted November 6, 2018 Share Posted November 6, 2018 yeah powerglide coolant pump and vent filter 4 1 Quote Link to comment Share on other sites More sharing options...
rotorhoe Posted December 3, 2018 Share Posted December 3, 2018 So Phils Rotarys only had white vinyl for door cards and I want black... so now I own the white ones, is spraying them with black fabric paint possible? Do I prep through standard measures of wax & grease remover then spray as usual? Any advice welcome pls thanks 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 3, 2018 Share Posted December 3, 2018 New vinyl? That's the best case as it won't have had silicon armour all crap sprayed on it. Vht vinyl paint/dye till your hears content 1 Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted December 3, 2018 Share Posted December 3, 2018 White is the perfect base for camo door cards. Just say’n... 1 Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted December 3, 2018 Share Posted December 3, 2018 @64valiant did you do a RX-2 coupe upholstery recently? If not do you have any camo material for some door cards? 1 Quote Link to comment Share on other sites More sharing options...
64valiant Posted December 3, 2018 Share Posted December 3, 2018 8 minutes ago, kiwi808 said: @64valiant did you do a RX-2 coupe upholstery recently? If not do you have any camo material for some door cards? did a 2 sedan. got a 4 coupe to do early next year. but camo is best purchased off ebay or ali express. a wax a grease cleaner will be good to clean before spraying them. with little bits ive sprayed before hand like door handles and arm wrest pays to heat the can and the subject up 1st make it get a good coating and also dries really well. also found vht the better vinyl dye (paint) presuming the doors are press welded with patterns be the easier way to paint them and cover them again. edit or if you really want black ones sell the white ones and buy these cardshttps://www.trademe.co.nz/motors/car-parts-accessories/mazda/interior/listing-1852444192.htm some vinyl and cover them black. or get the pattern you want on them stitch to vinyl through a layer of foam and then put them on the new cards. always found the vht and other vinyl dyes wear off on common places of use eg holding the door open with your foot, tops of doors and around winders where been covered in black vinyl you wont have wear problems. 1 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted December 3, 2018 Share Posted December 3, 2018 What about vinyl wrap the vinyl? i might be over-estimating what's possible. 1 Quote Link to comment Share on other sites More sharing options...
dabuzz Posted April 17, 2019 Share Posted April 17, 2019 Solid project, going forward nicely, have they used black etch primer? - seems unusual. Quote Link to comment Share on other sites More sharing options...
rotorhoe Posted April 17, 2019 Share Posted April 17, 2019 4 hours ago, dabuzz said: Solid project, going forward nicely, have they used black etch primer? - seems unusual. Thanks! Durepox for engine bay and unsure for underneath just know it’s not UV protectant. Quote Link to comment Share on other sites More sharing options...
