Sign in to follow this
kdotlowe
Kdotlowe's YB100s
Any yamaha dealership that sells dirtbikes should have it, failing that try somewhere that sells Yamaha jetskis
Share this post
Link to post
Tried that. Unfortunately all out of stock. I was pushing my luck and hoping to get some today haha!
Share this post
Link to post
Sourced some Threebond and sealed the cases.
Installing the disc valve cover & gear selector.
620250249_Photo15-01-1961331PM.thumb.jpg.9711de6c1fe49a4cdc535dc0bf0a0109.jpg1217185888_Photo15-01-1962124PM.thumb.jpg.b9f1485ebd10ef377a6591b0dd780563.jpg
Looks like I'm missing a bunch of circlips and other misc hardware. Will have to dig around the box the engine came in to see if I can find everything before I can continue.
Share this post
Link to post
This is great to watch. One day id love to rebuild my spare YB100 motor for my F5 to this spec. Keep up the good work dude
Share this post
Link to post
Cheers bro! All a learning experience for me so here's hoping it runs!
Share this post
Link to post
Found a box full of misc parts which contained some of the parts I required - the joys of building an engine from a box of parts. There's a few variations of the YB100 with mine being the earlier model. Seeing as this engine was in pieces when I purchased it, I'm not sure if a piece I can't find is missing or just not needed. Currently referring to 2 seperate schematics and unfortunately my engine seems to have pieces from both...
Installed the kick start shaft after a bit of fluffing around with gear orientation. Also installed the clutch basket.
Turns out my clutch plates are at OEM measurements. No wear on them at all. I'll be using them again so I've left them in some oil to soak overnight. 1056088423_Photo15-01-1995836PM.thumb.jpg.79567d4ca430d5207c0bc8396c45edf9.jpg
Share this post
Link to post
@Truenotch cheers bro! Looking forward to your build thread!
Got carried away and installed the points/magneto. Realised that I need to find a replacement side emblem, mine is bent to buggery.
Also placed an order with Yambits for a 0.75mm oversized piston. Toyed with the idea of going 2mm over, but I think I'll keep it conservative for now. Once the piston arrives I'll send the cylinder off to get a re-bore and hone.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
