cubastreet Posted August 29, 2018 Share Posted August 29, 2018 I just bought a ride on mower with a Kohler engine. It's an OHV twin cam. I assume it has two valves, so why would they put two camshafts in? Their website says better cooling, more power (600cc/16hp!) and longer life, but I can't think how this would be true. Marketing gimmick? Or is there something in it? Quote Link to comment Share on other sites More sharing options...
mjrstar Posted August 29, 2018 Share Posted August 29, 2018 Ability to run a wider valve angle than SOHC. . In reality it probably means they can use the same cylinder head casting and exhaust /intake setup with a number of different engine capacities and hp ratings saving themselves tooling and manufacturing costs. 3 Quote Link to comment Share on other sites More sharing options...
Muncie Posted September 1, 2018 Share Posted September 1, 2018 Curious is this double under head cam? EG Pushrod with a cam per cylinder in the block or a cam in each head assuming its a twin. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted September 1, 2018 Share Posted September 1, 2018 16hp is probably single cylinder I would assume... Quote Link to comment Share on other sites More sharing options...
cubastreet Posted September 1, 2018 Author Share Posted September 1, 2018 Yeah single cylinder, two camshafts in the block. Quote Link to comment Share on other sites More sharing options...
