Bling's AE70 Hardtop
Bling
  • 2 months later...
  • 4 months later...
  • 6 months later...
Didn't do much over winter as I can't finish rust work till it's warm enough to park it outside all day to dry.
So just a quick update, will try get the next one out a bit quicker.
Have been pulling the front end apart to send parts away to be worked on. So figured i'd replace all consumables while I was in there. Out came the steering rack, which had about 5mm of grime on it, along with crossmember. Whipped both those out and left the engine in the bay supported on blocks. Excuse the blur. Rack and cross-member are now clean as a whistle. Replaced the tie rod ends and boots on the rack.
Pulled the suspension out, chopped it and sent it off to Barry @ MRP to work his magic. Brakes also came off for a "service". Wasn't till I took the wheels off I realised this car came with the big brake option, 200mm of stopping power. Winding down the windows would likely slow the car faster.
The old:
New 276mm vs old 200mm, with Wilwood calipers to match (too lazy to find that photo):
Bits from RockAuto, three orders so far, filling my cart as I work through the car. Anything consumable is being replaced to save it failing later on. To a point anyway, not made of money.
So that's it for now, aiming to have it on the road by the end of summer, pending rust work progress. All of the above bits will hopefully provide some motivation to keep working on it in the meantime. Choice.
  • Like 9
  • 4 months later...
  • 4 months later...
  • 4 weeks later...
  • 4 months later...
  • 1 year later...
  • 2 months later...
