Footeys 1994 land rover doscovery tdi
footey
23 hours ago, 00quattro00 said:
Best way would be to compound turbo it. Use the standard turbo and run an extra 10psi into it with a gt2860 or similar. I was going to do that with my 300tdi but ive gone with an Isuzu 4bd1t and msa gearbox.
It's super easy to do and you don't have to make much, will give a far wider powerband than a vnt or single turbo, trick will be to stop the r380 exploding
mmmm i might have to look into this, having to rebuilt my r380 box, done some research dosent seem many people have compound boosted these,  seems max boost is about 20 psi,
might have a research into this
Ashcroft transmissions do a heavy duty bearing upgrade for the r380, also fit an oil cooler to it, easy enough to do as the fittings are there it just doesn't go anywhere.
20psi is max what you would run on the standard turbo by itself
I don't think the intake manifold will pose much of a restriction.
Won't find much info on compounds because people seem to like vnt turbos but they are no good without and ecu control, all modern diesels are compounded now
