Sign in to follow this
kicker
Kicker's C50
There are so many sweet cub builds for inspiration.
Some babe built this lush number
And this makes me breathe a little heavy
Share this post
Link to post
Blushing.
Fizzing over what your gonna do dude. Always loved your old small bike builds.
Share this post
Link to post
I'm a fan of this saucy ride
Not sure what I'll do just yet but it'll be skinny wheels, bars etc
  • Like 8
Share this post
Link to post
If you're going to bobberize it, do you want to swap the frame from this for your old frame with the cut rear mudguard?
Winky wink...
Share this post
Link to post
I'm not sure what I'm doing with the back end yet, I like the idea of keeping the guard as most do get cut off but they can look a bit daggy if not done well, I'll keep ya posted.
Check out the knobbly.
One thing I realised when filling out the form to re-register was that I hadn't thought about what colour I wanted it to be, I had to choose quickly as I was short on time but have since settled on one but you'll have to wait to find out.
Share this post
Link to post
I have started ordering some parts, just some bars, a headlight and some grips. Also dug out this wee number that I'll put on.
  • Like 8
Share this post
Link to post
I have stripped everything down now and there are a couple things that I need if anyone has any spares. I'm after the crush tube that goes between the bearings in the rear wheel and I also need a tyre to replace the knobbly currently on the back.
Share this post
Link to post
4 hours ago, KKtrips said:
Whats the plan next, blast it and paint it?
Yeah, will need to do a mock assembly beforehand with new engine and controls etc. Then can clean it up. The tank was looking a bit iffy with some rust around the bottom but after a quick cleanup I think it will be ok. Will need to citric acid/electrolysis it though as it has surface rust on the inside.
Share this post
Link to post
24 minutes ago, Steelies said:
what diameter's the rear axle?
12mm, runs through some 6301 bearings. My post nightshift measuring abilities say it needs to be 59mm but would need to check again :) You got some tube in stock? Would be super handy, can still source them new from the looks at least.
Share this post
Link to post
7 minutes ago, Steelies said:
i'll see whats on the shelf, top shelf that is
Hope you're wearing a short skirt and no panties...
Share this post
Link to post
Chur muchly!
Share this post
Link to post
My tank was fairly rusty on the inside so thought I'd give this electro rust removal a jam.
Bubbles
Amps
Science!
Yucky
I have pulled it out a couple times and given it a scrub and it's starting to look good.
Share this post
Link to post
Oooo, tell me what I need to do get in the queue for some of that very exact same treatment?
Share this post
Link to post
It's super easy
Bucket, water, washing soda, battery charger, sacrificial mild steel. 1 cup of washing soda to 60l of water, postive lead on sacrificial steel negative lead on part to de-rust, profit. Can do it for you if you want.
I pulled the tank out after 8 hours and it is looking good, all the rust on the outside is shiny once the black residue is wiped off, I think I'll biff some screws in and rattle it around then give it a final dip.
Share this post
Link to post
You working tomorrow? I might swing by and ding a ding dang my dang a long ling long.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
