  • Replies 837
11 minutes ago, Bearded Baldy said:
Tell me more about this plug?
SP21 9 pin.
https://a.aliexpress.com/_mNYOsUL
It's not as sensitive at low pedal pressure as my $$ BOC digital control pedal (it's literally got the drive by wire pedal unit from a Dong Feng truck inside 😂)
But @chris r reckons swapping a different type of potentiometer into it should fix it.
Awesome thanks for that, my knowledge of tig is from an old scratch start repco jobbie with disposable bottles, so anything is an improvement.
Resoldering a new pot is within my abilities though.
Maybe.
It has taken me 4 years to empty my little bottle of c02 . The cert for the bottle lasts 5 years.
The gauge says zero but she is still pumping out c02 lol. I need to fill it up before it runs out completely.
Winning
after buying the multi230 xcel arc, what like a week and bit ago, its still sitting in its box and that sucks a bit however i been real busy so whatever.
but now after these posts about the unimig envy - all i seem to get is posts on socials about them - shit they look pretty trick. even way more user freindly and the single and double pulse mig options are lush.
but yeh crikey they are a fair chunk more moolah.
  • 3 months later...
Repco had 25% off Cigweld as part of their Bathurst weekend sale...
Took a while to get here from Aussie, but finally arrived today (got the pedal elsewhere though as RRP is $215AUD and Repco NZ wanted $850!)
I don't exactly need another tig as my BOC AC/DC is still going strong and I've been using my Xcel-Arc multi for DC duties, but the Cigweld has a pile of features that I've been wanting to try and a decent duty cycle.
37 minutes ago, RUNAMUCK said:
 F argosheild fill
$230
Who are you getting that through?
I'm paying $180ish for F bottles.
Actually,
I exaggerate.
It was $224.
$20 each way for pick up and delivery. So yeah, about $180 for the gas.
Southern gas services are in rolleston. That's about a 60 minute round trip from mine.
$20 each way is a lot less admin that trying to find two hours to drop off and pick up.
I own an argosheild bottle.
One fill lasts me 6 years.
EDIT, When I close to bottle valve after use.
I bought the cylinder back when BOC abused to fuck out if their monopoly, and raped and pillaged/robbed everyone blind.
$120 or more per year for bottle hire (in 2000) bottle cost $600. Based on that metric, the bottle has now paid for itself three times over.......
Fuck BOC.
My Electra-Beckum 200 doesn't get much use at home these days, mainly exhausts and panel repairs.  I went to weld some plate a while ago and it was real shit...ended up doing a good enough weld though. Next time I use it there is no wire feed. I get all involved trying to find out what could be wrong with the wire feed motor, but it all seems ok - I give the wire feed knob a twist and all is good again. The wire feed has probably sat in the same position for a couple of decades, giving it a turn wiped some shit off and cleaned the contacts.
Often the wire has rusted and then either jams or slips in the feed rollers or gives super shit contact on the tip and certainly doesn't help the liner any.
Do yourself and the machine a favor and trim the old crusty shit off the roll to fresh wire and then youll probably find its ALOT better.
Or not. Maybe im not Jewish enough?
Chur
Rusty wire is a real issue for welders which don't see much use.
I get 5 years out of an F gas bottle. So I'll only buy 1kg wire spools. The last 5kg I had turned to shit from corrosion.
My old lincoln mig had that problem and the fix was to peg a piece of oil soaked cloth between the spool and the roller inside the mig. I wrote the word "MIG" on my oil can so whenever I oiled something I gave the mig cloth a squirt.
I've got about 3 metres left on my 15kg spool, I must do at least a metre per year. Wire is still good, but it was quality stuff, whatever I buy next will be the cheapest I can find and be totally shit.
