footey Posted June 3, 2018 Author Share Posted June 3, 2018 i do alot of skiing through out the winter im just going to leave this running on low, mint as =) have enough space between the back of the rocker cover and firewall to fit this in, will do a tech article when im installing it for all you other peps who are wanting to install one, have a design for a custom air box to re route the air up to the windscreen 2 Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 3, 2018 Share Posted June 3, 2018 Oh mean yeah I never thought of firewall mounting. I always figured mount under one of the interior wells in the back. You'll probably want to run a separate battery for it tbh to make sure you.can still fire the old girl up at the end of the day. Quote Link to comment Share on other sites More sharing options...
footey Posted June 3, 2018 Author Share Posted June 3, 2018 i thought id mount it high up on the firewire, i thought about under interior wells in the back, but then wading through water sitting in water, might swamp the unit, on the fiewall up high that will be the last of my worries if the water is that high 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 4, 2018 Share Posted June 4, 2018 When i used to do winter runs down to the south island if it rained my doors would freeze shut at the lake in tekapo. so I'd run an extension lead out and leave a fan heater on low all night while at the hotel definitely recommend. If you have bugger all in the way of door seals and gaps everywhere you'll want plenty of heat blowing in. 1 2 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted June 10, 2018 Share Posted June 10, 2018 Keen to see how this turns out. Quote Link to comment Share on other sites More sharing options...
footey Posted June 12, 2018 Author Share Posted June 12, 2018 so everyone is updated i have brought said heater and waiting for its arrival will do a tech thread on here once i get it and install the thing, allready buzzing with mounting ideas so far this is the plan Mount it in this said box, chop the handles off and take the lid off, maybe depends if the lid rattles , chop holes in the bottom for piping and also chop holes in the side for ducting Quote Link to comment Share on other sites More sharing options...
footey Posted June 12, 2018 Author Share Posted June 12, 2018 Quote Link to comment Share on other sites More sharing options...
footey Posted June 12, 2018 Author Share Posted June 12, 2018 am then going to attach the box to the firewall with some 90 degree angle brackets, doing it this way as im not wasting time making a box for it to sit in, the box protects it mostly, and its all off the shelf components which saves time Quote Link to comment Share on other sites More sharing options...
footey Posted June 12, 2018 Author Share Posted June 12, 2018 but not looking at the fact of splicing my air intake pipe for the heat into the snorkel air line, that way it has no chance of sucking up any water Quote Link to comment Share on other sites More sharing options...
