Carsnz123 Posted May 27, 2018 Share Posted May 27, 2018 (edited) Going to upgrade the brakes on my 260C. Seeing @kicker used S12W calipers with success that's my first port of call. On tard there's a set off an 06 hilux but they're stamped S12waa. Is there any difference? I'll have to use adapter plates because the plan is to use 13" mustang discs so bolt pattern is not a worry. Edited May 28, 2018 by Carsnz123 13" discs not 11" Quote Link to comment Share on other sites More sharing options...
Goat Posted May 27, 2018 Share Posted May 27, 2018 There are s12 and s12 + 8 Calipers. I think one is for vented, and one for solid discs. I'm running s12 + 8s in the Z. And thats for vented discs. Also, just FYI. If you need to rebuild them, buy willwoods. As i went the s12+8 route, and even at trade it was ~$600 to buy and fully rebuild them. $300 more and i could have had brand spanking new, lightweight willwoods. The S12 calipers are cast iron and weigh 236498236kg each. Quote Link to comment Share on other sites More sharing options...
kicker Posted May 27, 2018 Share Posted May 27, 2018 I haven't come across the 12waa ones, main thing to be wary of I think is how far they stick out. The S12+8 (43mm + 34mm pistons) are narrower than the S12W's which are narrower than the S13W, it's not by much but I have to shave some of the outer ribs on my S12W's so they would clear my rims. Rebuilding these calipers is spendy as Goat says, mine are working ok but ideally they need new pistons but cos I'm cheap and because not racecar I have bought some brand new repro calipers for $225 delivered instead of $213 + shipping just for the pistons. What master cylinder are you gonna use? Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted May 28, 2018 Author Share Posted May 28, 2018 Not 100% sure. I'm going to put discs on the back so something 1" or so. I think an early 2000s patrol one bolts on to the booster. I've got another MS112 crown one which might be a good option. Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted May 28, 2018 Author Share Posted May 28, 2018 looking at these discs. https://www.ebay.com/itm/Front-Brake-Rotors-And-Ceramic-Pads-1994-2004-Mustang-Cobra-Mach-1-Bullit/282215940007?fits=Year%3A1999|Make%3AFord|Model%3AMustang|Submodel%3ASVT+Cobra|Engine+-+Liter_Display%3A4.6L&epid=2155665364&hash=item41b5617fa7:g:9AgAAOSwE2da1iuE&vxp=mtr @kicker where did you get your calipers? Quote Link to comment Share on other sites More sharing options...
kicker Posted May 28, 2018 Share Posted May 28, 2018 An Aussie shop called Online Autoparts, just got em off TradeMe as that was the cheapest way I could find. What are the measurements for the disc? Just a note the PCD of the stock 260C discs isn't 114.3mm but close to 103mm Quote Link to comment Share on other sites More sharing options...
