AMR300 and AMR500 talk
~Slideways~
I've recently discovered these, I've stuffed around with with SC12's but never knew about these little buggers.
A bit of a search on here and it looks like some of you guys have played with them, stupid Photobucket has fcked the details from 5 or 6 years ago though, so I thought I'd start a topic specifically about them.
$200 USD!
https://www.aliexpress.com/item/mechanical-supercharger-car-gear-supercharger-Turbocharger-Roots-Supercharger-for-Displacement-1-2-2-2L-model-AISIN/32273573307.html
It makes me want to buy one and think about possible applications later...
An AMR300 might suit my Honda N360, it could even be a bolt on if driven off the cooling fan pulley. The carb is mounted with a rubber joiner so it would be easy to swap to something else.
Maybe I could use a bike carb?
It may not be a good idea due to rarity of parts but the idea is so tempting, surely it would be ok on 4 or 5 psi?
Who has played with these and carbs?
  • Replies 58
Mark had one on a velobike with a briggs and stratton. Was a bit of a beast apparently. Cant remember his screen name but you will probably find something in the two wheels section if you look hard enough
Yep I found that, some info but most of the photo's were hosted by photobucket so are gone now.
3 minutes ago, tortron said:
Hey, i have an amr500 and a v pully. And the piping/flanges that came with it.
A 1 1/2 or 1 3/4 su would suit pretty much anything that the super charger would
The big amr500 might be a bit much for a 360cc two cylinder?
Perfect.
You engine inhales 165cc per revolution. The amr 300cc. If you drove it at 1:1 the difference between what it can fit, and what the blower wants to ram down its neck manifests as boost. I'd nave to nut out what psi that would make.
1 hour ago, Firetruck said:
10-5s velobike was pumping over 20psi from the 300. It could have done with some meth to keep the temps down, but it worked well with the drawthrough setup.
Man, 20psi! I had a sc12 on 4agze which is basically the same thing but 1200cc. For a short time it ran 10psi and no intercooler, the outlet pipe got FCUKING hot real quick and the ECU must have pulled timing because it ran like a sack. Then intercooled and it was happy. (Then turbo'd and it was even happier lol)
2 minutes ago, RUNAMUCK said:
Perfect.
Sounds like you are the man to know haha
