Muncie Posted May 26, 2018 Author Share Posted May 26, 2018 Fuck you....... you small non magnetic object 4 Quote Link to comment Share on other sites More sharing options...
Alfashark Posted May 26, 2018 Share Posted May 26, 2018 Done a throttle body adaption now it's back together? Quote Link to comment Share on other sites More sharing options...
Muncie Posted May 26, 2018 Author Share Posted May 26, 2018 No i didnt. i don't have VCDS cable yet only went as far as flushing cleaner through the external ports on the throttle body so i didn't disturb it to much. No oil in the intercooler pipes which i was happy about. I'll remove it at a later date if ok give it full going over or just replace it with a new one if its not to costly. Quote Link to comment Share on other sites More sharing options...
Alfashark Posted May 26, 2018 Share Posted May 26, 2018 Ahh sweet. They tend to run like a bag of dicks and create weirdness if they don't get adapted again after being pulled apart. Quote Link to comment Share on other sites More sharing options...
Muncie Posted May 27, 2018 Author Share Posted May 27, 2018 Found a non VCDS method to do a throttle adaptation after some googling seems to have worked. Throttle butterfly dinked around and buzzed for 30 seconds so fingers crossed i guess. Quote Link to comment Share on other sites More sharing options...
Muncie Posted May 30, 2018 Author Share Posted May 30, 2018 Hello IRD I would like to add Rockauto to my list of dependents i pay support for. 3 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 8, 2018 Author Share Posted June 8, 2018 Swapped out spark plugs and liquid dinosaur filter this morning. Typical jap import the date on the side is 6 months newer then the car so thatll be around the last time it was changed. Full of black shit as well no doubt it'll be much happier idle improved instantly. 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 8, 2018 Author Share Posted June 8, 2018 Because general maintenance is boring snuck these bad boys in with a massive amp. 2 more amps to go in to run everything else need to save for some more speakers. Hidden real well and have bolted thru the floor so no one is nicking them in a hurry. 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 10, 2018 Author Share Posted June 10, 2018 I lunched a wheel today  stupid stretched tyres! They offer no protection to the rim will keep an eye out for some wide tyres for it. Keen to see what 265's would look like all round instead of the 225's they were new and came with wheels at time not necessarily my preferred choice. Just a bad curb rash barely moving but once it contacted had to cringe and back up, will get it fixed. Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 11, 2018 Share Posted June 11, 2018 Pretty sure you can't blame the tires for that, boss. Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 11, 2018 Author Share Posted June 11, 2018 12 minutes ago, kyteler said: Pretty sure you can't blame the tires for that, boss. Nope been 3 years since ive hurt a wheel. The difference is i was looking for a chicks address i was visiting not at the curb.......what a dumbass. Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 11, 2018 Share Posted June 11, 2018 Blardy chicks mayte, more trouble than they're worth. 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 26, 2018 Author Share Posted June 26, 2018 Im no front wheel drive guy but CVS shouldn't look like this huh? Quote Link to comment Share on other sites More sharing options...
Muncie Posted June 26, 2018 Author Share Posted June 26, 2018 Rockauto.com sez no Quote Link to comment Share on other sites More sharing options...
Muncie Posted July 10, 2018 Author Share Posted July 10, 2018 Surprisingly this thing hasn't given me any real grief since sorting the rooted cvs. Only one slight gremlin ive noticed after giving it berrys it runs a little rough and feels a bit doughy which has led me down the dark art of data logging. What to do with this stream of info is a bit over my head but it has me looking at the fuel pump or pressure regulator as a culprit. Other then that it fucking RIPS!! Im terrified of breaking it though so nana around in it getting good gas mileage 99% of the time, i did surprise a soarer driver the other week which has got me liking it again. 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted September 7, 2018 Author Share Posted September 7, 2018 Finally bought a VCDS lead and licensed Software version and plugged in tonight and did a full scan fuck me this had a "list" as long as my arm of fault codes. Ive saved them cleared and rescanned only one came back throttle body related so i sussed out the procedure for an adaptation did it, rescanned and now its happy. The amount of things that also suddenly seem happy now is impressive. I recently hired a tech at work who is fluent in obd programming mitsi's hes built a 10 second lancer so i think i can trust him to have a crack at this..... after he has a practice on his Jetta hes just bought. 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted September 9, 2018 Author Share Posted September 9, 2018 Scanned again today after clocking up 600ks Code came up for air loss between turbo and throttle. So pulled the diverter valve and cracked it open luckily its been replaced with a GFB unit. Surprisingly it doesn't run a seat for the plunger to seal on so i wound it down a bit harder to try get it seated firmer and will see about some new o rings that the plunger seals on. Quote Link to comment Share on other sites More sharing options...
Muncie Posted December 9, 2018 Author Share Posted December 9, 2018 So i think i know more about Volkswagen control systems then i ever thought i needed to know. And it boils down to this..... 3 Quote Link to comment Share on other sites More sharing options...
Muncie Posted December 10, 2018 Author Share Posted December 10, 2018 Ive got the list of things needing attention down to 3 recurring faults which dont stop me driving it its just irksome. When this thing is on song its a hoot to drive! Ive landed a new better paying job for next year so will chase more power with some tuning and a exhaust and buy a small ecobox to daily. just ordered a new oem airflow meter today as the original is near death. 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted December 16, 2018 Author Share Posted December 16, 2018 Fitted a boost gauge this weekend and think i may of Figured out why this thing is temperamental highly strung and runs rough after a decent bit of WOT....... its running 21psi of boost! And on a standard cat and exhaust which looks suspiciously like a na one at that. So my list of mods to be done in new year has shrunk back to just a 3" exhaust. No wonder it hates these 25+ c days. Quote Link to comment Share on other sites More sharing options...
