  • Replies 45
years ago I had a later model black 2nd gen 30M diamante, it wasn't a bad old barge went semi hard (for what it was), perhaps a bit ahead of it's time being mid 90's with a 5 speed tiptronic  trans. (i think my 2004 wagon still has a pretty similar trans too)
Interior of your machine looks pretty similar to how I remember mine.
I had a jdm 2.5 also. Was an amazing car. It was one car I regret selling. Looked like the black one above.
Good luck with it. It looks like its worth keeping
Must have been an expensive car when it was new?
My dad had a 2.6 povo spec one for a company car. I think it was the first car dad did a max speed run with me
Apparently it was over $90k when new (which I find hard to believe myself!) The previous owner's brother bought a GTO brand new but found it impractical so traded it in some months later on this.
The 2.6L Magna is so weaksauce compared to the Diamante - 120hp vs 220hp, beam axle rear suspension vs multilink (for JDM FWD) or double wishbone for AWD, shit Aus built low quality interior etc. The 1st gen Magna I had in Aus was noticeably not as well built as the JDM or even Todd built Galant/Sigma equivalents I had in NZ.
  • Thanks 2
Saw this on Trademe too, as a typical Mitsubishi foamer I, had too take a noesy at the listing. I have always liked the shape of the early 90s Diamante's. There ain't no 30R-S examples like this around now.
Glad that it has gone too a good home.
Ok now this is where things get a bit more serious.
Myself and Damien just collectively bought this, a flood damaged 1992 GTO twin turbo - he wants the engine and I want the rest of the driveline. It has all I need to convert to 5 speed manual (would have preferred 6 speed but they are harder to come by, especially for this price), large 4 pot brakes up front, bigger vented brakes in the rear, larger turbo diff and axles and the 17" OEM wheels which I like the look of. It looks to be lowered too so those struts could be swapped over.
Now I just need to book a trip back to NZ some time soon.
  • Like 6
  • Sad 1
  • 9 months later...
So I finally came back to NZ in December and gave the car a bit of a clean up, found some original 15" wheels (that I probably wont end up using now), and then put it on gen 1 GTO 16" wheels:
Took the 17" wheels off the parts GTO including Enkei alloy spare and extra 17" as spare
Obtained some gen 2 GTO brakes along with the gen 1 GTO front brakes from parts car (rear gen 1 brakes are same as stock Diamante). Also large plenum 380 manifold obtained to modify.
  • Like 6
  • 10 months later...
