16 minutes ago, JustHarry said:
I can have a look at mine tomorrow.  Not sure if they have different sumps in different vehicles though
Pretty sure there is at least 4 different sumps.
Can also have a look at my Hiace one tomorrow too.
  • Replies 585
2 hours ago, dmulally said:
I need to find a 1kz and have a look under one.
Ironically I have got the Jag humming quite well so the starter carb finally fixed itself although it is running off a boat tote tank.
I should prob start a thread on it.
Messenger_creation_4E8E616E-34F6-451D-B3CE-326CA5CB2BC0.thumb.jpeg.b6df57d05014ef8f0eae177b4f23163c.jpeg
On 05/07/2026 at 16:39, dmulally said:
The s-type is a bit of a cunt because not only does the sump have to clear the cross member but also the steering.
There are ways around that of course but more work.
I recon a rear sump from a granvia would be your go there
17 minutes ago, Yowzer said:
I recommend M57. Easy to work on, makes lots of power, lots of parts available.
I have one in the chev about 5 meters from the jag now and it probably wont fit with the turbo in the stock position down low due to steering and chassis rail. I had the same problem on the chev which is even wider.
Top mount would fix that but would then it might stick out of the bonnet of the jag. It's a tight package in the s-type as the nose pinches unlike the XJ6. I'll do a tape measuring exercise in case some poor cunt in the future is googling and finds this thread.
On 06/07/2026 at 08:26, dmulally said:
Does anybody have any strong opinions on the td27t either way? Seems to be pretty cheap and in greater numbers than all but the 1kz.
I have certed 2x vehicles with them , that I remember because they went surprisingly well
One was in a navara, from memory it had custom manifolds, a big turbo, and a tickled up pump. That one was a accelerate in 2nd gear and it was just on the cusp of wheelspin the whole time type of power, I was quite surprised
The other one was a terrano, and he had done a few things to it but head porting was the main difference power wise
  • Thanks 2
diesel with ported head ? sounds like i needs a lucky bumpy stick added to open valves longer as well ?
