Sunbeam Posted February 27 Posted February 27 Thanks OSers for helping me think through this. Confirmed egr cooler internal split. It’s bypassed, and I will investigate having the ute tuned and deleted. 9 Quote
Sunbeam Posted June 12 Posted June 12 Just started working on the ute again, rego off hold now. Since blocking the egr, I still have untidy cold starts. There is an intermittent misfire from just above idle to about 1800rpm until it warms up. If you are driving, no misfire is apparent. It turns out the PJ won’t report injector contribution PID which is annoying, so I made a leakoff test rig from tubing, pump bottles and duck tape. It worked mint. Now, I was certain I had a duff injector (less certain now) because it has 4 new glow plugs, it’s no longer using coolant since the egr cooler was bypassed, and shows no signs of head gasket issues. I thought I detected a very light injector knock by ear at light cruising load. As you can see, the leakoff doesn’t look bad. That’s warm engine, 1 minute idle, the black line is 40ml. Diesel peeps chime in please. Quote
Rookie Posted June 12 Posted June 12 You can have a injector with a bad spray pattern that leaks down ok. With it idling and missfiring, unplug the injectors one by one to see if you can isolate it to one injector. If you can isolate it to one injector then try moving it to another hole and see if the missfire moves with the injector, if it does, then good, if it doesn't then you might have low compression on that hole. When you deleted the egr did you get it tuned or did you just put a blanking plate? Quote
Sunbeam Posted June 12 Posted June 12 Did the unpluggy bit. Also got the scan tool to run deactivation test which it passed. Miss is too intermittent to isolate. EGR hasn’t been coded out yet, probz get a tune at the same time because why not. Quote
dmulally Posted June 28 Posted June 28 Been down a bit of a youtube rabbit hole on VW 1.9 TDI swaps. Are they a common swap in NZ or like the 4bt in that they are popular overseas but we are stuck with Isuzu's? 1 Quote
cletus Posted June 28 Posted June 28 I've never been asked to cert one if thats any indication, have done couple of golf's which have been tuned though Not many people do diesel swaps really, have done a BMW 6cyl and a Mercedes om606? in 4wds , and a v8 duramax in something else I assume its because they are reasonably expensive to get in NZ compared to how much power they make? 2 Quote
deankdx Posted June 28 Posted June 28 13 hours ago, dmulally said: Been down a bit of a youtube rabbit hole on VW 1.9 TDI swaps. Are they a common swap in NZ or like the 4bt in that they are popular overseas but we are stuck with Isuzu's? I was interested after seeing Top Gear USA decades ago probably do "project sipster" https://motoiq.com/project-sipster-part-7-sipster-indeed/ the goal was 7 seconds 0-60mph, 70mpg fuel economy for under $7000, and they did that but the fuel economy was over 80mpg (3 Litres per 100km ish from memory) I never looked into it further, was cheaper just to buy a car with that engine if wanted (I'm in Australia, and the gearbox conversions were in USA) there are kits to bolt them to various gearboxes, I considered one using a hilux 5 speed (W58 or similar) but Robot Cantina has an early VW diesel bolted up to a T5 (kit available) in a Chev S10 pick up in USA (current project, will be turbo'd supercharged etc later) 1 1 Quote
dmulally Posted July 3 Posted July 3 I guess the kiwi version of the 1.9tdi in popularity would probably be the 1kz? 1 Quote
Alfashark Posted July 3 Posted July 3 Probably correct, but 1.9tdi are common enough in NZ. Absolutely massive aftermarket support for them, or mix and match from the VAG parts box. PD100 would be the most common flavour over here, a new set of nozzles and you're away laughing. PD130 builds on the above, bonus points if it's a BLT code from a Fabia RS as that gets all kinds of nice goodies like a forged crank, titanium fracture-split rods etc. PD150 is the garden variety version of the above, but has longer head bolts which are handy for winding the boost up. If you get your hands on a BLT, they do much better than they should (PD130 means Pump Duse 130hp - Unit injection, so one injector pump attached to each injector). Darkside in the UK tested as many bone stock Fabia RS as they could get their hands on and not one produced less than 140hp at the wheels, with the highest being close to 180hp. Get thee to a wrecker, ASAP! 1 1 Quote
dmulally Posted July 4 Posted July 4 18 hours ago, Alfashark said: Probably correct, but 1.9tdi are common enough in NZ. Absolutely massive aftermarket support for them, or mix and match from the VAG parts box. PD100 would be the most common flavour over here, a new set of nozzles and you're away laughing. PD130 builds on the above, bonus points if it's a BLT code from a Fabia RS as that gets all kinds of nice goodies like a forged crank, titanium fracture-split rods etc. PD150 is the garden variety version of the above, but has longer head bolts which are handy for winding the boost up. If you get your hands on a BLT, they do much better than they should (PD130 means Pump Duse 130hp - Unit injection, so one injector pump attached to each injector). Darkside in the UK tested as many bone stock Fabia RS as they could get their hands on and not one produced less than 140hp at the wheels, with the highest being close to 180hp. Get thee to a wrecker, ASAP! I recognise some of the words in that post. Mind if I send you a flirty pm to pick your brains? Quote
Alfashark Posted July 4 Posted July 4 3 hours ago, dmulally said: I recognise some of the words in that post. Mind if I send you a flirty pm to pick your brains? Feel free mate, happy to help! Quote
JustHarry Posted July 4 Posted July 4 On 03/07/2026 at 12:14, dmulally said: I guess the kiwi version of the 1.9tdi in popularity would probably be the 1kz? What are you going to put it in? A 1kz isn't going to win any races in stock trim but can make plenty of power pretty easy 1 Quote
dmulally Posted July 4 Posted July 4 1 hour ago, JustHarry said: What are you going to put it in? A 1kz isn't going to win any races in stock trim but can make plenty of power pretty easy 65 S type jag. It's unsellable in this market and Ive had a gut full of the XK engine. Quote
RXFORD Posted July 4 Posted July 4 Deezil spam. Funny that ya can't pass a wof because a sun faded or frayed seatbelt might kill you, yet they are fine to sling round a 400+kg lump of iron. 4 Quote
JustHarry Posted July 4 Posted July 4 11 hours ago, dmulally said: 65 S type jag. It's unsellable in this market and Ive had a gut full of the XK engine. Wonder how you would go for space with a 6cyl diesel like a 1hd or something like that. Either way even with a 1kz you would be better with a mechanical fuel injection pump so no wiring . Easy to find rwd gearboxes for them too Buy a crashed granvia and use the auto and wiring loom if your that way Inclined 1 Quote
dmulally Posted July 4 Posted July 4 1 hour ago, chris r said: How about om662, Om602 or om606? Have you seen what 606's go for? M57's are cheaper and they are getting up there. That they have the ability for mechanical pumpage has them clear of M57's for me though. Quote
dmulally Posted July 4 Posted July 4 1 hour ago, JustHarry said: Wonder how you would go for space with a 6cyl diesel like a 1hd or something like that. Either way even with a 1kz you would be better with a mechanical fuel injection pump so no wiring . Easy to find rwd gearboxes for them too Buy a crashed granvia and use the auto and wiring loom if your that way Inclined Tighter than a nun's fanny in the S type bay. Quite impressive that blokes squeeze V8's into them. Today's job is finding a blockage in the fuel line after getting gummed up with stale fuel due to lack of driving it. 2 Quote
