Unclejake 10,071 Report post Posted February 6 What if I filled the entire engine with diesel from the oil filler tube, let it sit for a few days and then drained it out. Reckon it'd creep up past the rings? 1 Share this post Link to post Share on other sites
Yowzer 20,316 Report post Posted February 6 That's a very unusual story. How would you overheat the oil without over heating the water? If there wasn't enough water in it the temperature gauge wouldn't have changed, I had that happen to an engine once when it blew a hose. If it has been proper hot then things could have warped a bit. Bores may not be round anymore. Might just be worth ditching this one and slapping the turbo gear on that other engine. 3 Share this post Link to post Share on other sites
Mof 8,022 Report post Posted February 6 Drop the sump and check the big ends? Probably can't, some crossmember in the way or something murican. I've had the v8 out of a f450, took the cab off to get to it. Share this post Link to post Share on other sites
Unclejake 10,071 Report post Posted February 6 Yeah, it's 4x4 so lots of rusty stuff in the way. I think the filling the block up with lubricant idea has some merit (thanks OS). I hadn't thought of that Share this post Link to post Share on other sites
Hemi 7,834 Report post Posted February 6 3 hours ago, Yowzer said: That's a very unusual story. How would you overheat the oil without over heating the water? If there wasn't enough water in it the temperature gauge wouldn't have changed, I had that happen to an engine once when it blew a hose. If it has been proper hot then things could have warped a bit. Bores may not be round anymore. Might just be worth ditching this one and slapping the turbo gear on that other engine. By running a bearing. that will get the oil hot very fucking quick and zero change to coolant temp. I will say that i work on truck motors and not smaller vehicle so it might be different. But in my experience is if the oil temp raised so quick it didnt get to the cooling system, thats bearings , they aint part of the cooling system and thus the oil will hold ALL of the heat. Yeah there are oil coolers but if you watch coolant vs oil temps while running up you can see how lagging/ disconnected they can be. Not a wail, but my experience. tear me apart if you will. 2 Share this post Link to post Share on other sites
Hemi 7,834 Report post Posted February 6 Atf is good for freeing up bores too, has the detergents in it for that, wont evaporate etc. As for if its a bottom end issue,try turnign over via crank bolts? if these slack then it might be in the pistong rings. if theres none its in the crank. 1 Share this post Link to post Share on other sites
Testament 7,819 Report post Posted February 7 check the negative/earth connections of the batteries to the chassis and engine to chassis if you can, bad connections there could also cause poor cranking while hemis explanation sounds plausible it seems very odd that you would even know the oil got overheated without a temp gauge unless he has some story about the thing seizing up and smoking out of the breather or oil cap with the temp gauge cold or something like that. Which he would have told you? or is he being a bit cagey about exactly what happened to it? Share this post Link to post Share on other sites
cubastreet 777 Report post Posted February 9 How hard is it to rebuild a diesel injector pump? I can get a good deal on a 93 surf (2LTE?) that has a leaking pump. Share this post Link to post Share on other sites
Yowzer 20,316 Report post Posted February 10 Yeah my thoughts exactly (re: Tom's post). I've personally never seen a "small" engine cook the oil from a bearing failure, generally because it either makes so much noise, locks up or spits the rod before it gets a good glow on. If that is what happened though, or any failure that results in overheated oil, I think it's pretty safe to say it's an anchor. Share this post Link to post Share on other sites
