Fibreglass, Carbon Fibre, Paper Mache - The composites chat thread
Roman
  • Replies 306
18 hours ago, Roman said:
I've heard sandbagging works well but havent tried it.
Re: Vac pump I just recently bought this and this:
https://www.aliexpress.com/item/32596684494.html?spm=a2g0s.9042311.0.0.27424c4dxRsPKo
https://www.aliexpress.com/item/32580819002.html?spm=a2g0s.9042311.0.0.27424c4dxRsPKo
So far so good, pulls vacuum right down to zero on the gauge when you've got a good bag seal. If I leave the pot shut off it'll hold a vacuum overnight at same place on the gauge.
I bought the pot as well, because I use it as a catch can for any epoxy that might zing up the pipe to stop it from stuffing the pump.
Just have a second pipe on it instead of that filter.
But also good for degassing epoxy or rubber or whatever else for other projects. And having the large volume means if you've got a tiny leak you dont lose overall pressure as quickly.
The only catch was that it doesnt come with vacuum pump oil, and you need special oil that doesnt evaporate when the pressure gets really low.
I think it's flammable or something like that so they cant ship it internationally.
Can get it from Repco though so no dramas.
I've still got a love/hate with vac bagging though. Can be very fiddly.
If my glass blowing is successful would you be able to de-gas some tubes for me?
Possibly, what does that involve? Just putting them in vacuum pot for a while then back into atmo?
I live in Morrinsville now but if you post them down or drop them to my Dads place in Glendene I can give it a go.
17 hours ago, kicker said:
Have seen a few cheapo setups using compressors from dehumidifiers and fridges.
I guess it also involves punching captain planet in the dick when you release the refrigerant
I do genuinely wonder how bad it is compared with how much fuel people waste. I mean carbon monoxide is pretty bad too but it's suddenly ok because everyone is doing it.
If i put in a one way valve that might work for a while.
I was thinking of making a glass tube with metal contacts in it.  A long tube to suck out the air, and when it's done you heat & pinch off the tube.  Much how nixie tubes are made.
It's not as bad as cfc's, one gram of r134 is equivalent to 1410 grams of CO2 as far as warming is concerned, cfc's were equal to 8500 grams of CO2! :)
Would you be better off purging the tube with an inert gas before pinching off?
I was thinking flush with argon at atmo' pressure, then vacuum out what i can.   And i have 2 special 'getter' materials that's needed for this application.
Interesting, however internet tells me it's still not as bad as we think. "Every gallon of gasoline burned creates about 8,887 grams of CO2" So that means a full tank of gas (Say 10 gallons or ~38 litres) produces around 89k grams of C02. More internetting says car aircon units use about 350+ grams of r134.
So i mean it's not ultra bad for the environment, worth a few tanks. Then again Diesel is even worse. And how much heavy ship fuel does a cargo ship use, or a coal power plant...
Wtf.. isnt 8,887 grams 8.7 kg? That doesnt seem right? Lol
5 hours ago, Roman said:
You guys are polluting this threads atmosphere with emissions chat
Sorry, yes sidetracked.
Found link for someone posting aliexpress carbon https://www.aliexpress.com/item/32785723466.html?shortkey=ymqQvqei&addresstype=600
Anyone else got links for the other products you need? I'd buy locally, however I just want to have a bit of a play at some point with minor investment
Need wax, pvc mould release, resin and cloth like in above link. Have found some examples below locally and aliexpress, any advice?
Roller kit (Locally seems to be quite expensive) - https://www.aliexpress.com/item/33030075213.html?spm=a2g0o.productlist.0.0.2e667dfet84S09&algo_pvid=a1a6fc64-1021-466b-ab21-bd5a817d7f84&algo_expid=a1a6fc64-1021-466b-ab21-bd5a817d7f84-0&btsid=9ba89dce-fc3a-4287-a2d3-3f842992ca12&ws_ab_test=searchweb0_0%2Csearchweb201602_8%2Csearchweb201603_53
Resin - https://www.trademe.co.nz/motors/boats-marine/parts-accessories/paints-glues-resins/listing-2234612263.htm?rsqid=4c6e53a236e548c0b5a47f89a666875b-001
Mould release wax - https://www.trademe.co.nz/motors/car-parts-accessories/paint/listing-2236031923.htm
PVA release - https://www.trademe.co.nz/motors/boats-marine/parts-accessories/paints-glues-resins/listing-2236138894.htm?rsqid=0c17b6ce555b4b90b126bbd4163d8f4a-001
  • 4 weeks later...
