  • 4 months later...
Na sorry don't have the coupe anymore. Sold it to a guy in Dunedin for parts for his.
Both door glasses and the driver's 1/4 we're broken though
  • 3 years later...
Seeing it with the guards off, it's become clear you should drop that rover v8 into it.  Slap on a 4bbl manifold with a 390cfm Holley and enjoy nice v8 sounds in a lush old Toyota cruiser..........
  • 1 year later...
  • 2 years later...
3 hours ago, Bearded Baldy said:
Just an fyi that you probably know already. If you use 1/2-20 thread it works out to .050 per turn.
Just used m6. Dial gauge will tell me how far open the valve is
Not guna lie. Im intrigued  and  confused all at the same time Harry. Whats the  go with the cut up head and valve opener bracket thing yourve made?
Just getting it ready to go on a flow bench
  • 2 months later...
Re brake upgrade.   504? Peugeot discs and hulux 4pots  bolt on.   20mm vented disc.    Downside was  because the peugeot is so obscure the discs were hard to get.   @sheepers gave me the name of some parts store in aussie that  had DBA  cast a whole lot  mainly for crown conversions, cant recall the name sorry
I
I'll be going upto a 15 anyways for tyre options .
I'm looking into putting an hz caliper over ms112 vented disks reason being there is decent pad options for hz calipers. They're the same as what's on the car now just a bit wider to accommodate the wider disk
Just need to see how the mounts sit
Are the 504 disc for the ms65 spindle or ms112 disk replacement.
