JustHarry Posted June 28, 2021 Author Posted June 28, 2021 This thread is an abortion. Needs a clean up. Since half the pics dont work Anyways. This got a wof last week. Then i cut 1.5 coils out. Needs more tbh Also fitted some 205/70/14 to the factory steelies One day i might paint it. But not today 1 Quote
JustHarry Posted July 3, 2021 Author Posted July 3, 2021 Did this this morning at work. Centre bearing was noisy and loose. Hilux centre with the crown housing bolted around it. Sorted Much quieter Quote
JustHarry Posted July 6, 2021 Author Posted July 6, 2021 When it rains my feet get wet There is also a cold breez from under the dash whilst driving I thought u would investigate. So i pulled the dash out found some yucky Then this happend Then this happend Not ideal But a pretty good result considering its a 70s toyota. Will be a straight forward repair Quote
JustHarry Posted July 6, 2021 Author Posted July 6, 2021 Still on the look out for a 3.36 holden diff for this. Ht/hk/hg Should be corse spline but will pull an axle and check Quote
JustHarry Posted July 17, 2021 Author Posted July 17, 2021 Got the patch in welded and seam sealed up. Shouldn't leak water into the cabin now. Most of it is covered so just flicked a bit of black on it for now Quote
JustHarry Posted July 19, 2021 Author Posted July 19, 2021 Added power steering. No more struggling in carparks 1 Quote
JustHarry Posted July 20, 2021 Author Posted July 20, 2021 Painted the tacho Now to get the numbers made Quote
JustHarry Posted July 23, 2021 Author Posted July 23, 2021 Got the tacho looking hot. However not working so hot. I dont think its reading accurately. But i also have no way of checking that so maybe im imagining it 1 Quote
JustHarry Posted August 4, 2021 Author Posted August 4, 2021 Dash is in. Tacho works ok. Not accurate but looks the part. Quote
JustHarry Posted August 4, 2021 Author Posted August 4, 2021 I havnt had a fan on this for a while as all my viscous are either siezed or nof doinh anything so i took it off so it didnt sound like a van Carfully route planning and nof sitting in traffic was the key to not overheating it. Anyways. I had the radiator record recently and at the same time i got the shop to put a bung for a temp switch in. So tonight i put an electric fan in it Its actually out of a 1992 galant out in field 1 Quote
JustHarry Posted August 23, 2021 Author Posted August 23, 2021 Ive had this mz11 soarer front cut sitting around for a while because it has a 5mge in it. So i decided to pull it today and start preping for it to go in the ms65 After lockdown will get all the cam covers vapour blasted and paint them The wiring is a pain to follow Im tracing the wiring for the airflow meter from the ecu plug which is all inside the body loom fml Atleast the engine loom is mostly seperate 1 Quote
JustHarry Posted April 17, 2022 Author Posted April 17, 2022 Ended up putting another 5m in this. One showed up on marketplace and I acquired it. Was a bit scabby inside. Ended up swapping cam/lifters/oilpump/sump/can chain and tensioner(Near new)/ and did a headgasket and stem seals whilst it was apart. from spare motors to make it a good thing. Looks like a low kms motor as theres no visible bore wear Then this happend Then this also happened Running good again . Making doort noises Even got a good photo or two taken of it . Wow much high definition so quality And that's much story 1 Quote
JustHarry Posted March 18, 2023 Author Posted March 18, 2023 Went to nats Had a few dramas alternator shit the bed on the way up ended up in repcos carpark for a while trying to mend the old one. But it was beyond economic repair Found one that was close enough on the shelf and with some questionable wiring and spacing it was made to fit Saturday we left the pack and went af far north as the south island allowed It's been pretty rumbly in the back for a while now and @RUNAMUCK proclaimed with absolute certainty that it was a left rear wheel bearing . And that he could smell gear oil with his all smelling nose . And for a second time he was correct about the faintest of oil leaks that hadn't even presented itself outside of the brake drum yet And the wheel bearing was pretty toasted too. So todays job was replacing them Quick trip to butler auto for some hg holden bearings and then slipped them on with a press all nipped up this arvo and nice and quite 3 Quote
Popular Post JustHarry Posted February 9, 2025 Author Popular Post Posted February 9, 2025 Chopped up a wagon 10 Quote
