Jusepy82 Posted January 13, 2018 Share Posted January 13, 2018 hey , so I've decide to start working on my 77 ford escort panel van after her sitting in my shed for the last 5+ years. tonight I stripped the sump off and also pulled off the clutch setup and flywheel. i don't know where the motivation has come from .. (my wife doesn't know either) I'm not sure what this sump is off ,.if its 13 or 16. Here's some pictures so far. Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 13, 2018 Author Share Posted January 13, 2018 3 Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 13, 2018 Author Share Posted January 13, 2018 Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 13, 2018 Author Share Posted January 13, 2018 If you have any ideas about clearance between engine sump and steering rack , hit up my project discussion. Thanks. Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 31, 2018 Author Share Posted January 31, 2018 Hey guys , tonight I decided I'd find out where the play in the drivers door hinges is coming from. Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 31, 2018 Author Share Posted January 31, 2018 The top hinge pin was easy , the bottom hinge pin was a total different story . I even soaked her over a couple of days , tonight I ended up getting a bit rough and ended up butchering it .oh well another thing to fix. Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 31, 2018 Author Share Posted January 31, 2018 When I finally got door off I found a nice rust hole.. Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 31, 2018 Author Share Posted January 31, 2018 I also decided too remove the right front wheel and check out the brake caliper , as I had problems when it was running with seized calipers and it's been sitting for awhile soooo. Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 31, 2018 Author Share Posted January 31, 2018 Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted January 31, 2018 Author Share Posted January 31, 2018 Here she is off , had a few cold ones while chipping away in this heat. Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted March 4, 2018 Author Share Posted March 4, 2018 Soo today saw a crack in the will and thought hello , bog. I got itchy fingers and got out NY angle grinder and flapper disc.opened up a can of worms I have... Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted March 4, 2018 Author Share Posted March 4, 2018 Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted March 4, 2018 Author Share Posted March 4, 2018 What are your guys thoughts , can discuss on my project build. Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted July 7, 2018 Author Share Posted July 7, 2018 Solo today was the perfect day outside to start pulling the drivers side wing panel off. I have brought parts for my brake rebuild but havnt started reassembling them yet. Have been thinking about sidedrafts also , whether to fit them or just run weber carb. I'm a big fan of dropping down the brake booster by lowering the mountain holes on it but will stick to normal carbs for now. Anyhow I drilled out all the spot welds with a 6mm spotweld drill bit to find it hadn't done the job properly so I ended up using the 8mm spotweld drill bit and a lot happier with that. Got all the spot welds drilled out and started to peel the pannel away from the frame , ran out of time as was working on the eskie while baby was asleep and guess what... She woke up before I had it off completely. I'm not sure how the guard is joined onto the front bumper/panel as looks solid as...any ideas? Sorry bout all the babbling , was a solid hour and a half in the shed and was enjoyable. Anyway here's some pics.... Quote Link to comment Share on other sites More sharing options...
Jusepy82 Posted July 7, 2018 Author Share Posted July 7, 2018 Quote Link to comment Share on other sites More sharing options...
