bonkas Posted December 10, 2017 Share Posted December 10, 2017 Hey Guys, Hopefully someone can help me here. While my engine has been in bits it seems my container of bolts has been mixed up with another vehicles... My New Pistons, Rods, Crank, Block and Flywheel are at the engine builders being lightened, balanced etc. Issue I have is they need the pressure plate bolts and the crank pulley bolt - neither of wich I can find. Does anyone know what these should be so I can find/buy some more? Quote Link to comment Share on other sites More sharing options...
bonkas Posted December 10, 2017 Author Share Posted December 10, 2017 I have found this info so far, hopefully someone can confirm.. Crank Center Bolt (MD376614) Pressure Plate Bolts (MF241251) - M8x16 Quote Link to comment Share on other sites More sharing options...
dwlee Posted December 11, 2017 Share Posted December 11, 2017 What you need to find is Mitsubishi's electronic catalog either CAPS (older) or ASA (newer) so you can look up bolts etc. Also, check out Austarion forum as they will have access to the Starion parts catalog. Quote Link to comment Share on other sites More sharing options...
bonkas Posted December 11, 2017 Author Share Posted December 11, 2017 Yep I have both CAPS and ASA but the oldest vehicle they have is a 87 L200 which seems to also have the G63B engine, this is where I pulled these part numbers from. No-one has a scrap G63B or 4g63 lying around I can scavenge the other required bolts from? Quote Link to comment Share on other sites More sharing options...
Ranter Posted December 12, 2017 Share Posted December 12, 2017 I'll have a number of crank pulley bolts I can post one, but just go down to Mitsubishi and order one. They're quite often stretched so I buy new ones. As for pressure plate ones, I don't have those but if Mitsubishi don't have them just go to a bolt place with your flywheel and get some that fit. Another thing I don't like using second hand bolts for. Quote Link to comment Share on other sites More sharing options...
bonkas Posted December 15, 2017 Author Share Posted December 15, 2017 Couldnt find a listing for ARP ones... but I did pick up a new crank bolt and flywheel bolts which are genuine parts so should do the job. Only question is if the crank pulley is correct - we will see when they arrive! Quote Link to comment Share on other sites More sharing options...
fuel Posted December 15, 2017 Share Posted December 15, 2017 Have you lost the bolts for sure, or you just don't know which is which? Crank pulley bolt looks like this: And flywheel bolts look like this: If you have lost them completely, you should be able to buy them from Mitsubishi. If getting second hand bolts, make sure you get the correct length flywheel bolts as they are different between auto and manual. Quote Link to comment Share on other sites More sharing options...
fuel Posted December 15, 2017 Share Posted December 15, 2017 oh whoops, I see you're after pressure plate bolts. They are fairly standard bolts and look like this: Quote Link to comment Share on other sites More sharing options...
bonkas Posted December 17, 2017 Author Share Posted December 17, 2017 Yup i've ordered pressure plate bolts and the crank bolt, I believe there is also a spacer that goes with the crank bolt which I also cannot find - Due to other people working on different vehicle and having a disregard for other people stuff all my nuts and bolts have been moved, mixed up with other vehicles stuff etc, only things I have been able to identify as mine is the pulleys and gears etc. grrr makes me mad, so much for a straightforward re-assembly. Quote Link to comment Share on other sites More sharing options...
