4g36 engine specification sheet
HughCull
Cant find 4g36 Mitsubishi Saturn engine specs anywhere. Unsure if 4g3 Series have universal specs.
Wanting to find a user manual or any form of spec sheet for things like ignition timing, valve clearances and general servicing information.
Any information appreciated cheers
I've got this manual which has specs for the 4G32, 4G33 & 4G37:
https://1drv.ms/b/s!AjIWJwhrv2O0wkM5Ti17CoD983K_
(link is just to my private onedrive, so totally safe - if it asks you to sign in there should be an option to skip it and go to the doc).
Looks like most of the specs are the same across the 4G3x range, but that might be a good starting point if you haven't already got it. No 4G36 in there directly sadly.
I've found a lot of the specs are similar but yeah can't find direct specs for a 4g36 anywhere. Cheers for the manual
  • 2 years later...
