removed the battery tray and huge washer bottle bracket.
31073148_10155776641109775_9139508758681740945_n.jpg.30fa1ee469e041380bd1912c624b5602.jpg
found the perfect radiator in my shit i have in garage .was oe of the ones i had for my mk2
its a 70mm thick rx2 alloy rad and a bloody good size.
31189923_10155776639839775_5173042061801103008_n.jpg.bb735c0ff0c3fd71dd48a2f45baa95f5.jpg
so i measures it all up and cut the slam panel to fit it.
31059549_10155776639904775_3349428287662747325_n.jpg.317958741f498a881294ab19ff57da87.jpg
31056907_10155776640089775_6940018828953860321_n.jpg.2f39d9ad0e321a0ed859b6b7f6946561.jpg
31072839_10155776640034775_7652519469556755927_n.jpg.907d9cfe21945487b59c19d7bb149064.jpg
 should be a good fit.
31073361_10155776640304775_3277996910907112262_n.jpg.fbd1157d83521d7040630444be6745a8.jpg
31070468_10155776640144775_769521897533134608_n.jpg.9b5ab432cba9b7781d6ef250357c3a51.jpg
started making the bottom and got it welded it...made it to incorporate the bottom bracket for the rad to sit in.31131312_10155776640194775_9120434641318843406_n.jpg.548eb74a2557c454ee5b7374dc874fc3.jpg
31120854_10155776640659775_4793244929567856881_n.jpg.f56046dbd7925e8af7d9709e781cd8c3.jpg
31062170_10155776640899775_1964377446948489542_n.jpg.2ceae1dcaf193eb266afc31532ced814.jpg
thats it so far.
Share this post
Link to post
just a quick 1 to say im getting excited /aroused
they are all most done.
man when they get here i will throw that motor back in the hole just to see what they look like in there.
31576795_10155792255427669_4989476092017377280_n.jpg.2b547f9e36d185586285d409f43c31db.jpg
Share this post
Link to post
well that's a fucking relief    .... the bonnet shuts...without having to make a bubble in it or try and track down a aussie one.
and i have lots of room around the motor and heaps of room for a 14"fan now that the davies craig waterpump plate is on and the radiator is in the slam panel.
Share this post
Link to post
Look what turned up today....
Still a little work to do.but love it.
Shame the trumpets I watched for fucking agers to find don' fit.
Share this post
Link to post
6" pod filter adapters I'm wanting to use for trumpets finally arrived ... once they trimmed to fit 6 if them in there and molded into 1 and painted....... should be perfect...
Only took 5 weeks on back order from summit racing.....2 days to get to NZ and 16 days to get to me from Auckland.... good old NZ ay.
Now I can work out how much more to remove from the engine bay....pull motor and box out for clean up and build..and start welding all the holes in the engine bay up before mak8ng a rotisserie to do the underside.
Share this post
Link to post
did a wee bit today .
finally got the breather tank to fit.
sorted out the rear of the engine bay (again) so the throttle body linkage does hit anything will have room for the Idle air controller and the trumpets will fit.
and still cleaning bits on the motor.
Share this post
Link to post
raided the off cuts bin and maybe not so off cuts pin today at work..and started making a rotisserie
also postie turned up with the fuel pump im going to try and make work.....
its from a 07 falcon ba turbo...so should pump enough gas.......going to try and reto fit it in the factory fuel tank.
cheers
Share this post
Link to post
Apart from shocks that's every nut and bolt out..
Build a rotisserie... strip the underseal off the underside..... then off to to be blasted.
38914428_10156020457989775_6373643407549530112_o.jpg.1e72ce0a47e63c40a9eb2f9dffed3a99.jpg
Share this post
Link to post
Finally picked up my diff for the mk3 ..thanks again Karl . 1350 overall width. 3.7 ratio.( perfect) 25 spline ( not bad) axles and bearings in very good condition....
Open diff. ( just need to find a falcon 25 spline LSD ) ( had a few spare a while ago)
Diff head bearings ....fucked. ( replace once find LSD .)
42983441_10156142700894775_484006672109404160_n.jpg.d4029ef5d641bb002c6dc6f54b75e542.jpg
42977849_10156142700959775_9014227281526128640_n.jpg.ca5b42d4a223ae9a40096a0f009944e4.jpg
43145692_10156142701004775_4221895716018061312_n.jpg.332b0fdf234627df5a69e6108f6cd6d1.jpg
Share this post
Link to post
huge thats to Pete (valiant) for a 25 spline LSD carrier  and the tools he made to check the breakaway. and it ends up being 100 ft = 135.5nm so thats pretty good led me to think it may have been shimmed . Pete also said it could be dirt /rust.
43201623_10156149349569775_9009350414880997376_n.jpg.31936907412f889e4e317d316101e51d.jpg
i decided to pull it apart and soak it for a few days but it turns out its pretty blood clean
43232838_10156149349609775_9037130173157212160_n.jpg.a03b003b245b9903dffc236cf0fed5be.jpg
so i cleaned it up anyway and it turns out it is shimmed.
43178851_10156149349699775_1802949609262153728_n.jpg.7539e157a48b4b6d39397f4f3670aa80.jpg
43237916_10156149349879775_344267351333535744_n.jpg.de4fea9c216192969a50d95a988dd07f.jpg
43151036_10156149349819775_8946381323828723712_n.jpg.b010fe9da87fef6bcbc1998baff0ad31.jpg
43155773_10156149349969775_5152524500956348416_n.jpg.c492bc9209bb27fd0280182774d273f9.jpg
i rebuilt it with some LSD oil i couldn't find the torque specs for the diff  ( @RUNAMUCK has some)but they didnt feel to tight taking them apart  so i just torqued them down to 30ftlbs. (will do for now as its only getting wrapped in cling film and put on the shelf till the complete diff is ready to be put together.)  i did recheck the breakaway torque again and it was spot on 100 ft again so that's awesome
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
