Evo powerd L200 thermostat housing
Jahprez13
This setup has already run the car reliably, but am looking to modify current setup, have herd remote Toyota setups are the best option, but due to wanting to hea engine run I will be using this setup for now, have parts being sent this week but would like to keep custom parts
A word of warning, the small port which appears the have a tempreture sender bunged into a piece of hose should be plumbed into a cold return loop back to the water pump (usually via something such as heater or turbo) to enable coolant flow to make the thermostat open. Otherwise you may hotspot the head even though the temp gauge may be reading low.
This was scribble 'A' for the rwd 4g63t in the mazda.
