  • Replies 111
  • Hyperblade
    112
So I decided to rebuild the cooling system in CAD as I'm going to need it for the ducting and it will make life easier.
This is the current plan.
image.png.42c10f1e013169d9ecc64f5cf5e6c73b.pngimage(2).png.1a8bc148a9529d10562ad58a3b8f971d.png
With the oil cooler facing down it makes the hose routing much easier, and shorter. Centering it also means the brackets are easier.
And that leaves the spare M22x1.5 port for a radiator filler which is much nicer then inline.
Then that only really one place to put the fan. Being on top won't be a bad thing as it will cool the oil cooler when on too (only on sitting in the pits).
Yes will be 3d printing a shroud extension for it to close it into the radiator.
In terms of what the bracket will be made of, haven't finalized that yet, but contemplating metal 3d printing just so I know it's not going anywhere, but would be roughly $205 USD for both in Stainless 316, (that's before optimizing it to remove material).
With having done it in CAD, it is now easy to change it to mount a larger oil cooler, or fan if required in the future.
  • Like 8
So multiple things on the go at the same time
I've done some research into options for the ITB's and the following is the conclusion.
Honda K20a = 94mm Bore spacing.
BMW S1000RR
  • $400 NZD
  • 48mm Plate
  • 80 mm bore spacing (Not ideal)
  • 3D Print Manifold
  • Reuse Fuel Rail
  • Reuse Current Injectors
  • 3D Print Trumpets
  • Electronic Standard
  • Has outboard injectors.
Pros: Really light. I have them already, I have the outboard injectors, Full CAD Model might be available from Prototipo. Electronic control as standard. Proven to work well by Dave.
Cons: Bore spacing not perfect, could be slightly larger. Need to bore the back side of them out slightly larger (can be done without affecting plate)
BMW S65 ITB
  • $650-$730 NZD
  • 50mm Plate
  • 98mm Bore Spacing (But I believe they can be moved on rail to suit what I need).
  • 3D Print Manifold
  • Reuse Fuel Rail
  • 3D Print Trumpets
  • Electronic Control Extra $ (Definitely don't want BMW one)
Pros: Bore spacing adjustable, slightly larger in size.
Cons: While they normally have standard electronic control that price is just for the ITBs so have to buy electronic motor.
Aliexpress OBX Individual Throttle Body
  • $640 NZD ($160nzd each)
  • 48mm or 50mm Plate
  • Custom Bore spacing
  • 3D Print Manifold
  • Reuse Fuel Rail
  • 3D Print Trumpets
Pros: Cheaper than EFI Hardware.
Cons: Have to work out linking them together, unknown quality, have to buy electronic motor.
EFI Hardware
  • $1200 AUD just for throttle bodies.
  • Any Plate Size I want.
  • 94mm Bore Spacing
  • 3D Print Manifold
  • Reuse Fuel Rail
  • 3D Print Trumpets
Pros: Will be quality item, come in linked pairs so only need to one join.
Cons: Price, have to buy electronic motor.
Jenvey K20 Kit
  • $4000 NZD
  • 48mm Plate (options for 50-51mm)
  • 94mm Bore Spacing
  • Includes Manifold
  • Includes fuel Rail
  • Need new Injectors to suit
  • Includes Trumpets
Pros: Known setup that has been tested against many other brands and has consistently bet them all.
Cons: Price, need to buy new injectors, have to buy electronic motor.
So this is where I'm at with the spacer for a set of BMW S1000RR ITBs, all just a prototype in PLA at present.
CAD model technically is just 1 parameter change to adjust from here to thicker spacer if someone needed one.
The intention is to actually 3d Print this in PACF/PAHT.
First up is this little spacer to hold the spring. The spring rotates with both sets of throttles and it's only purpose appears to be to put pressure on the driven throttles so I speculate it's to hold them against a seal and a bearing that has been shimmed to get plates in right location.
You can also see 2 shafts with gears on transferring the movement from the motor to the blades, so the gears are moving back and forth but not spinning, the shafts don't spin.
In the original setup it looks like these shafts are located into a hole on the other housing, however it's a sloppy fit, so I don't think it's providing any support, it's mainly just to stop the gears moving up and down to much.
So I've replicated that by putting in some aluminum bushes (will be glued in final version) so the gears won't be rubbing directly on the plastic housing.
I have done a full plate across the middle, except where throttle linkage goes, so that there is some strength side to side.
I've also put lips both sides just to help located it and stop it moving (even though it shouldn't once bolted)
Sealing wise the plan is to print some TPU gaskets 0.5mm thick.
The hole where the motor plug normally comes out will have to be made larger to fit the plug and some type of seal made around it, but confident that can be done in TPU as well. If spacer was bigger you could just take wires out of current hole.
I haven't worked out how to do the throttle linkage yet, it needs to be metal for the loads and ideally need to line up with the centerline of the existing one and not move around, so some sort of clamp arrangement I'm thinking either way the throttles will have to be resynced for any minor adjustment it might cause.
Normally I don't like bolting plastic up for sealing purposes as it deforms over time, in this case I think it's going to be ok as you are clamping the plastic between two aluminium faces and so a spreading the load out over a much larger surface area.
However if it needed to be printed out of aluminium then currently (before discounts) it would be $73usd delivered to my door.
So Dave mentioned this in the discussion thread.
On 15/08/2026 at 22:46, Roman said:
Ahh so the thing with the dual springs inside them.
The "resting" position for these throttles is about 5% open.
So you have to actively push them shut with ethrottle to close down the idle further.
If you can, get rid of that spring that holds them open like that. It's a real pain for ECU PID settings to work around.
Might make your linkages easier that way too.
So I looked into this and it looks to be a relatively simple fix, which can be done externally without opening them up.
This screw here adjusts it, it's a M4 thread, and takes a Metric 2 Allen Key, however I recommend you use one on a socket, this thing has red loctite on it and is really really hard to remove, your best to get it moving, then keep going in and out slowly. Otherwise you will round it off like i did, a Torx bit hammered in finally got it out for me.
PXL_20260821_050030657.thumb.jpg.fd722aed8d54b271c4ee775b654a667f.jpgPXL_20260821_050036897.thumb.jpg.97cb5ba90f9685b8b60a4fd6cba7f677.jpg
PXL_20260821_050148066.PORTRAIT.thumb.jpg.3d66d0a460635b63f27677d2a81deb73.jpgPXL_20260821_050123482.thumb.jpg.b3c7d55e3de4cc0e3b9938252a4fe1bd.jpg
Then you can replace it with a M4x20 bolt and that has enough depth so it's no longer resting on that extra linkage meaning the throttle blades are closed, it has no impact on how far they open (they continue to open fully).
This video shows it's adjustment
Forgot about the other side...
You would also need to adjust this screw OUT as well, to adjust the resting position of the driven side.
PXL_20260821_053314019_MP.thumb.jpg.5edf355ca3d7e4821aa17b3b6a39a373.jpgPXL_20260821_053317258.thumb.jpg.9c06e03aa6d4c8ff8aca03017f4068e6.jpg
So one of the concerns with spacing it out is the synchronization between the 2 banks of plates after extending the linkage.
The ITB's do support adjustment for this, but it's behind this pressed in insert.
Once the throttles are apart you can stack a nut in there and lever with a screwdriver to get it out (not much force required.
This allows direct access to the Metric 2.5 Allen bolt to adjust this. Note you can only really adjust this when the plates are closed (and when the other mod to the resting position is done)
