Hyperblade
Hyperblade's KP61 Racecar "KP61R"
So old engine is now out of the car, so time to work out what it weighed.
  • 144.91 kg - 3SGE Beams Gen 5 with lightweight flywheel (6kg), Exedy HD clutch, sq engineer Alternator bracket, echo/yaris alternator, sq engineering slim line water housing, water lines at back of head chopped, top cover chopped, altezza engine mounts, no oil, no intake, no exhaust.
  • 38 kg - J160 with cross member, gear lever + knob, slave cylinder, no oil
  • 9.48 kg - Stainless 4-2-1 Headers went back just past firewall
  • 7 kg - Blacktop throttles, SQ Engineering Adapter plate, Toda 75mm trumpets, Standard Altezza rubber spacer, and standard Altezza engine to rubber spacer plate, steel bracket for quad vacuum manifold, vacuum manifold and idle up valve and piper cross filter and fibreglass backing plate.
So in Total:
  • 161.39 kg Engine + Intake + headers
  • 182.91 kg Engine + gearbox
  • 189.91 kg Engine + Intake + gearbox
  • 199.39 kg Engine + Intake + headers  + gearbox
I honestly wasn't expecting it to be that high.
Share this post
Link to post
Up above I mentioned the stock water pump housing was 4.8kgs
It's also a huge chunk of metal, and has a idler pulley down low in an awkward place.
You can find AC/PS eliminator kits like this one.
http://k-tuned.3dcartstores.com/Universal-AC-PS-Eliminator-Kit_p_248.html
The issue is it puts the alternator even lower and I'm going to have a cross member there.
So looking at the options I decided to go with a water plate kit
This allows me to get rid of a lot of weight, run a lighter alternator, and keep it all away from the cross member.
I chose the older k-tuned kit which doesn't support the K series alternator, only because it was slightly cheaper.
I chose to only get the plate and the alternator bracket and pully. (not the water pump) as when I contacted K-Tuned they commented they had only used it in drag applications, and hadn't tested it in a road race application.
http://k-tuned.3dcartstores.com/Water-Plate-w-Alternator-Brackets_p_600.html
So why use an older alternator?
Alternator Weights:
  • K20a - 5.68kg
  • B18 - 4.64kg
  • D15 - 4.9kg
Cause they are slightly lighter!
Now ideally I would have gone with a B18 alternator but the shaft on it was too small for the pulley.
So D15 it was, however it wasn't a straight fit, I had to clearance the top of the alternator slightly to fit. But the other advantage was the plug is the same as the K20 alternator.
Sticks out a fair way, would have been nice to have it closer, but can't have everything.
Chose a Davies Craig EWP 115 (alloy 8140)
https://daviescraig.com.au/product/ewp115-alloy-12v-115lpm30gpm-remote-electric-water-pump-8140/ewp115-alloy-electric-water-pump-12v-8140
Australian made and with the Aussie dollar pretty good to NZ and shipping prices makes sense to go localish.
Only annoying thing is they don't have mounting points, they can just be held up by the hosing, however will have to see how that looks when I go to mount it.
Otherwise you can buy this bracket:
https://daviescraig.com.au/product/ewp-mounting-bracket-kit-ewp115-130-150-8700/ewp-mounting-bracket-kit-ewp115-130-150-8700
The pump can be PWM controlled, so i will do this via the LinkECU through a PWM relay, so it will be pulsed on an off to control the flow depending on the temperature.
So with this change I've cleared up some space, dropped 5kg and freed up some HP from the engine.
Share this post
Link to post
Next challenge was the intake manifold.
With the engine rotated around into RWD config the throttle body points directly at the firewall.
This is where you have so many options off the shelf as it's all been done before.
You can buy an adapter plate to fit an F20c (S2000) intake manifold to the K motors, but they look terrible so I didn't want to go down that track.
You could go Quad Throttle Bodies (with multiple options from different manufacturers, swoon...)
Straight:
Curved:
Kinsler mega dollar ones...
But this conversion is already going to cost a fair bit, so that can be an option for a later day...
So I ended up with the Skunk 2 Ultra Street Intake Manifold
https://skunk2.com/induction/intake-manifolds/ultra-street-intake-manifolds/307-05-0600.html
It has a rotatable plenum cover, which can be removed if you want to go crazy and port the runners and you can also buy spacers for it to increase the chamber size.
Supposedly it also gives 20hp over stock manifolds.
It also matches up perfectly to a 74mm throttle body (standard for the engine is 65mm) so I didn't need to port anything and it saved a lot of time.
The downside is the quality of the casting is not super great with some imperfections and I had to port match the thermal gasket to the head, which was disappointing as it should just be cut correctly from factory.
The other thing to note is the Idle Air Control Valve (IACV)on a Euro R is NOT the same as other K20'a Type R engines, i.e it won't bolt up, so I got an Integra R which fits..
Share this post
Link to post
