Honing a very small bore, tolerances?
kempy
I have a nitro engine that's NOS , unused but by the feel and look of it I think the bore sleeve is slightly crushed out of shape at the top, causing the piston to bind, this isn't substantiated yet as I don't have the measuring gear to substantiate this, only an eyecrometer.
I'd really like to get the engine going but lack the kit to measure and machine, does anyone here have a small accurate lathe at their disposal ( Pref  Akl.)  I'd love to own a small lathe, but alas..
Im not sure what tolerances to use or even how to bore an engine this small, but any help would be greatly appreciated
CHeers
Kempy
1 hour ago, kempy said:
Its a GMS 2000, 0.4 cu in. You're right with the ABC setup but it's so tight that I can't turn it over by hand ie. The piston moves freely for the bottom 80% of the stroke??
How big is the flywheel, I have a CMB .21 that feels like that just because the flywheel is hard to get a grip on
I do know they wear very quickly. And are expected to go out of tolerance fairly quickly.
I worked with a guy who raced nitro buggies. To save on rebuild costs he had machined a tool that would accurately crush/ squeeze the liner to get the bore back into tolerance. Seemed to work pretty well!
( He also machined his own heads with huge heatsink fins so he could run more aggressive fuels)
