Sign in to follow this
Tender Raisin
Raisins 1982 Toyota Corona Mkii GX61
The Good The Bad & The Ugly
From inspecting the car all the electrics worked, even the fender mirrors. The interior was mint minus a crack in the dash and the centre vent. Also a small hole in the drivers seat. I wasn’t a fan of the 1g-eu and it was leaking oil from every orifice, fixed to the auto box = a gradual 0-100.
The exterior was fairly straight but the paint was showing its age. Stone chips and a few imperfections were apparent but none of this worried me.
It was advertised as having no rust apart from some surface rust under the bonnet and 2 spots near the boot. I knew it would have more and boy I was right, yet I didn’t know how extreme till later down the track. A wheel well half filled with water was a bit of a giveaway and prodded around the boot for some clues. A few areas around the boot seal became apparent, but me being me haggled the price slightly instead of walking away.
On The way home I also worked out the suspension all round was rooted as the previous owner had removed the springs for the images in the above post above.
First Things First
  • Replaced the windscreen
  • Replaced rocker cover and manifold gaskets
  • Add a sump bung washer to stop oil leaking
And straight through WOF it flew. I was certain it would get failed on suspension, but some how it got through… so I carried on sailing the roads of Canterbury with some wicked body roll.
Share this post
Link to post
Tidy Up
I am a bit of a perfectionist sadly so I went straight to work tidying little odds and ends.
  • Visors were replaced with some from pickapart as the standard ones were tatty.
  • A dash-mat was made to hide the cracks in the dash.
  • Floor mats were added
I sent the car to a friend’s work to suss the rust in the boot. The rear window would need to be removed to get a bit more, but that’s a future problem. The only pieces I know of left are behind the rear wheels and rear window. I also had the rear bumper painted as it was an eye sore.
The next job on the list was to replace the cam belt & water pump but I was beaten to it.
Stop Right There!
Its first journey south to the big smoke of Timaru proved to be an expensive one.  Everything was going fine and stopped off home on the way back in Mayfield so I could get laughed at by my father for buying an 80s Toyota. I noticed a faint chugging sound, like the sound of a steam train when it leaves the station.
Hoping it was nothing I left home swiftly and headed for Christchurch. 30ks into my journey I approached some road works and slowed to 50km/h. As I put my foot down to get back up to speed nothing happened, the car stalled and I slowly limped onto the side of the road.
Thinking it had overheated as the gauge was being funny I let it rest for 20 minutes and tried to start it. It turned over but no luck. Thinking the worst such as snapped cambelt I left it alone. So Swann insurance came to the rescue and moved to car to Ashburton. Since I knew it was going to be a while for the tow truck I was just lying on my bonnet in the sun I had around 10 people stop to see if I was alright on a back road which I thought was quite impressive.
Verdict cambelt slipped off. It was old and disintegrating. Luckily The 1g-eu is a non-interference engine so no damage done.
Share this post
Link to post
Toyota Fest 2016
I was getting fond of the stock look. Deep Down I wanted it to be Low and on some Wide 14s. But I couldn’t force myself to commit just yet.
I planned to drive it to Cromwell for Toyota Fest in March 2016. A week out when I was cleaning it I realised my WOF had just run out. Took it in and bingo failed on rear struts. Managed to get these two days before leaving and got the WOF the next day.
This would be it first "big drive" since the cambelt incident, so was hoping everything would run smothly. It loved to drink the fuel however and it didn’t like going over the Lindis Pass. Think it slowed down to 40km/h at one point. Had to let all the angry people in their big SUVs past once I reached the top.
Anyway Toyota Fest was a success even got to throw it round 2 laps of Highlands to show its killer body roll.
Goal is to get it ready For Toyota Fest March 2018 at Cromwell again.
Share this post
Link to post
Time To Upgrade
So It failed its next WOF on the front shocks ad ball joints, which I knew was coming. So it was time to start spending some cash money, and finally get the thing low. I will keep all the old parts so if for some odd reason i want it stock height again it can be returned simply.
dspec_tt131 from here posted he was parting out his GX61. So I jumped on his modified S13 BC gold struts, to cut out the hassle of building my own. They also came with some RCA's. These have since also been crack tested and are ready for cert.
I also managed to get a brand new pair of MX73 BC gold rear struts and springs.
dspec_tt131 GX61
I have also pulled apart the front suspension and tidied it up. Replacing ball joints, tie rods, sway-bar links, and bushes. The wheel arches also got hit with some CRC Proseal.
Two months till Toyota Fest….. It’s going to be close.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
