I am planning out a long term project and want to start researching suitable engines.
It will start with a Dyna or Atlas, and maybe the engines available in these will be sweet, but I am probably going to be looking for a reasonable amount of grunt, so a 2.4 2L wont cut it.
I want to keep it as simple as possible, so it would need mechanical injection (or easily converted to it), 4 cylinder for the length, maybe a turbo, no electronics at all.
It would need to be reasonably grunty, parts readily available and cheap and bulletproof...
Any suggestions?
  • Replies 63
Isuzu 4bd1t.  3.9l 4cyl diect injected turbo. Super strong, last for ever and capable of making serious power
I have one that im fitting to my 110 land rover
13B-T?
Ya can convert a 1KZ to mech inject if you want, or turbo a 5L. What is its intended purpose?
I've made some decent power from a turbo 3L without damaging the engine but tbh it might be under a bit too much stress for heavy duty work. It could drag 3Ton of car and trailer very happily though.
I have a 4be2 in shed ( spare for my trucks) if you want dimensions etc ,my understanding is that the 3.3 3.6 3.9 4.2 are all pretty much interchangeable
I have a 4x4 Isuzu truck about the same size as the photo was used for towing a 300mm chipper in the bush ,I'm looking for a new deck for it preferably a tipping one
giz
1kz would be such a bad choice, will definitely want a truck based engine.
What type of transfer case are you thinking of using
Yea I had second thoughts after posting that. I want something truckish, low stressed but with some grunt.
The 100 series dyna 4wd system/transfer cases are mighty according to the local truck wrecker. I had a serious chat with him about what would make a good base. He did not rate the equivalent Izuzu, and was indifferent to the Nissans. I am a bit of a toyota fag myself.
Ok pm me early next month when I'm back in the country
Its either done 147k or 174k its a 1990 nks 250 got a hydraulic tail lift 3m deck got two sets of tyres road and mud grip
Gear linkage needs a grease was hard to change from 3rd to 4th but got lots better after I had finished towing out a 6x6 truck (I hardly ever use it except to get fire wood off a mates steep farm block)
Its 99% ready to take it for re vin ,just got to find out why wiper motor sounds like a concrete mixer and and spray a couple of panels where I cut out some rust ( around the back near the cab locks where they all go)
Offers
I originally for spares for my other trucks but just went so well so kept it
