flyingbrick Posted July 4, 2017 Share Posted July 4, 2017 So I have just ordered two Arduinos and a little color OLED screen for a car related project- I am excited as fuck to learn some new skills and also achieve something for far cheaper than otherwise possible (and in a way more interesting way, too) So @Ned and others- what have ya done/ what reading material do you think I should first start with. Edit.. also, back in the day I did a course on c++ and Delphi (it was 16 years ago) so maybe that will help (I can't remember a single thing about it all) 1 Quote Link to comment Share on other sites More sharing options...
Adoom Posted July 4, 2017 Share Posted July 4, 2017 Copy other peoples code and modify to suit. Before you could just use a phone... I made a GPS based speedo one time. It worked, but it was too laggy. I thing the problem was the refresh rate of the gps receiver thingy. My problem was trying to think of what to make.... 2 Quote Link to comment Share on other sites More sharing options...
h4nd Posted July 4, 2017 Share Posted July 4, 2017 Getting started: https://www.arduino.cc/en/Guide/HomePage https://www.arduino.cc/en/Reference/HomePage Don't worry about the code thing yet, it's nominally c++, but modified a bit to make it easier. Start the IDE, include the library for your thing, and off you go If you have specific problems, (maybe particularly car based stuff) ask here, and we'll answer, and build up some know how. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 4, 2017 Author Share Posted July 4, 2017 49 minutes ago, Adoom said: Copy other peoples code and modify to suit. Before you could just use a phone... I made a GPS based speedo one time. It worked, but it was too laggy. I thing the problem was the refresh rate of the gps receiver thingy. My problem was trying to think of what to make.... I haven't tried this stuff earlier for two reasons- lack of useful projects and the idea that they were too spendy and bulky to be used for permanent (set and forget) type projects. It feels foreign to me that you could have this programmable computer hidden away for the sole task of (for example without thinking too much about it) dimming your interior lamp and flashing your indicators...but then for $5 why can't it just do those things? I basically just want mine to display dash indicator symbols; handbrake, headlights, indicators, alternator etc which should be bloody easy (hard for me but an achievable goal) Quote Link to comment Share on other sites More sharing options...
Ned Posted July 4, 2017 Share Posted July 4, 2017 So i thought i replied to this already, but never hit submit. Guessing its one of those I2C LCDs? pretty sure there will be some example code for them on the interwebs somewhere for the arduino IDE. Just keep cutting and pasting example code together until it does what you want There will be some graphics libraries that can display simple images like that i'm sure. I've only recently started playing with the arduino IDE because in the old days it was just garbage and didnt do anything for me, but recently got a few WeMos D1 modules, and was insanely surprised at how easy it is to get libraries installed and example projects loaded etc. It all seems to just work and you dont need to know anything about micro controllers at all to use it. It's amazing... 2 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted July 4, 2017 Share Posted July 4, 2017 I'd like to whip up a simple gear indication display for my pos racecar as a little project, ideally it would calculate gear selection based on RPM signal and divide by speed signal, sure it won't display gear with clutch engaged. Am I dreaming or is this possible? also if it could control a separate LED or two for a shift light that would be handy. 1 Quote Link to comment Share on other sites More sharing options...
downtrail Posted July 4, 2017 Share Posted July 4, 2017 Almost anything is possible within reason. I started on this project a while ago using an arduino uno. It now embedded on its own pcb and been through many revisions and still not finished haha. <media> </media> 7 Quote Link to comment Share on other sites More sharing options...
downtrail Posted July 4, 2017 Share Posted July 4, 2017 Even started on a program to setup all the timings via a serial connection. 5 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 4, 2017 Author Share Posted July 4, 2017 Fuck this is exactly the discussion i was hoping for. These are the units i have bought @Ned https://www.aliexpress.com/item/Free-Shipping-0-95-inch-7pin-Full-Color-65K-Color-ssd1331-OLED-Display-3-3v-5v/32646204260.html?spm=2114.13010608.0.0.f8qGLh https://www.aliexpress.com/item/Nano-CH340-ATmega328P-MicroUSB-Compatible-for-Arduino-Nano-V3-0/32740641316.html?spm=2114.13010608.0.0.f8qGLh I liked this board because its so compact and i wish to hard wire it in. I'm just about to purchase an arduino code simulator which should make things easier for me. I did want a tiny screen but feel the one i bought may be a bit small.. just purchased one of these just incase: https://www.aliexpress.com/item/New-1-8-inch-TFT-LCD-Display-Module-ST7735-128x160-51-AVR-STM32-ARM-8-16/32816228162.html?spm=2114.13010208.99999999.264.1Qun1e It will depend on screen visability and brightness etc etc. I'm not wanting to do anything extremely flash.. i will likely separate the bigger screen into 6 quadrants each with its own symbol to display when necessary. I was going to have them all display fullscreen on the smaller display but am not sure how to tackle multiple icons at once- it may get a bit confusing having a sequence of different icons flashing up in repetition. Quote Link to comment Share on other sites More sharing options...
Lord Gruntfuttock Posted July 4, 2017 Share Posted July 4, 2017 Shit those bits are cheap. If I wasn't so time-poor I'd be building something just out of interest's sake... 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 4, 2017 Author Share Posted July 4, 2017 I figure why the hell not give it a go! even if it fails you have found some entertainment for the cost of a bag of potato chips 1 Quote Link to comment Share on other sites More sharing options...
Pelo. Posted July 4, 2017 Share Posted July 4, 2017 Following this, I'm very keen to try some arduino stuff. Its been years since I've soldered. I want to do data logging or something in my car. Quote Link to comment Share on other sites More sharing options...
Ned Posted July 4, 2017 Share Posted July 4, 2017 so heres a video telling you exactly what to do (first youtube result) but see how slowly the display updates? Arduinos and 'big' screens just go slow. Updating a whole screen takes a long time, and you can noticibly see it draw the thing you wanna see. It's not terrible, but just be aware that it wont be like watching a noprmal screen pop up a symbol or anything. still, not a bad way to go, especially when you're only updating a small section of the screen at a time 3 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 4, 2017 Author Share Posted July 4, 2017 Thanks ned- yep i watched that video last night- its actually how i discovered the larger screen. I cannot wait to get my shit! I think the main issue with TFT is that it wont be backlit (if i understand things correctly) where as my smaller oled screen will be. Still trying to work out if i can fit 2x oled screens to one arduino. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 4, 2017 Author Share Posted July 4, 2017 https://www.tinkercad.com/things/gKYtnrGMzoU-magnificent-crift/editel?tenant=circuits this is bloody cool for fiddling with the code. unfortunately no screen component (that i can see, ive been on it for about 2 minutes. Quote Link to comment Share on other sites More sharing options...
Ned Posted July 5, 2017 Share Posted July 5, 2017 Somewhere on the internet i saw exactly what you want... but cant find it this second, i'll keep trying. those LCDs run on SPI and i2c, just use it in SPI mode and then you can connect as many as you can find CS lines for. So they share the MOSI and SCK pins, and have a different CS pin for each LCD. MOSI is the data line, SCK the clock and CS the chip select, or slave select. You will likely run into RAM problems before you run out of pins as they often use a RAM buffer for the whole screen, and with a decent mumber of pixels (especially in colour) that could become memory hungry 1 Quote Link to comment Share on other sites More sharing options...
downtrail Posted July 5, 2017 Share Posted July 5, 2017 Buy a bread board and some jumper wires to make it easy to prototype diffrent projects. Youll thank me later lol 3.3V/5V MB102 Breadboard power module MB-102 830 points Solderless Prototype Bread board kit 65 Flexible jumper wireshttp://s.aliexpress.com/ryIrUJnY 2 Quote Link to comment Share on other sites More sharing options...
h4nd Posted July 5, 2017 Share Posted July 5, 2017 Also, the Arduino IDE is still shit, but: 1/ install the arduino IDE 2/Download / install MS visual studio community (make sure the tick the C++ option) 3/ Install Visualmicro from http://www.visualmicro.com/page/Arduino-Visual-Studio-Downloads.aspx Now you can program in MSVC which is a MUUUUCH better IDE (autocomplete, navigation etc) but VM also includes a (crude) debugger. You can read variables from the code while it's running, without having to fuck around installing lots of #ifdef debug Serial.print("\r\n Some thing happened"); #endif junk. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 5, 2017 Author Share Posted July 5, 2017 Thanks downtrail.. just bought two of those. I dont need two but fark what a deal- unbelievable. 1 Quote Link to comment Share on other sites More sharing options...
h4nd Posted July 5, 2017 Share Posted July 5, 2017 Also, get in the habit of doing loop / dropthrough code ( Non- blocking ). That gets helpful later when you've got lots going on. 1 Quote Link to comment Share on other sites More sharing options...
