Hurmeez' 1977 Mk2 Escort Estate
Hurmeez
  • Replies 152
First job we got on to was making some sport style quarter bumpers. The car came with a bent and twisted front bumper which would never come back to perfectly straight without heaps of work and I prefer the quarter bumpers on the mk2 so it was the logical conclusion to chop it up. P_20151127_102106.thumb.jpg.097849c3e37ab5d4a519f261265aa406.jpgThis first photo shows it after we had it in the press to get as much of the twists and kinks out of it as possible before starting. It doesn't look so bad here but it was much worse in person. Then I borrowed a fiberglass bumper off a mate and used that to mark up the steel and make a wooden buck.P_20151127_102235.thumb.jpg.3d882e4901b2a151c8f39c4febf2c4a4.jpgP_20151127_110524.thumb.jpg.d6200b394a737cd60f84529de3de71af.jpgP_20151127_112007.thumb.jpg.61a0052ec69e4baaad8a84549069537b.jpg
Sliced the steel bumper
Bent it round the buck (note the steel toe socks and crocs)P_20151127_115128.thumb.jpg.c81e18f95e14f471e309644de30cae22.jpg
And TIGed it up. P_20151127_144525.thumb.jpg.9fe3b4bc6fc50738943eee4bb1df03a9.jpg
The joys of having a dad with car obsessed mates...
A couple of things happened in the same day on this day. Firstly a mate of dad's had a couple of seats he was planning to put in a T-bucket he was building up. However, in his opinion the small amount of wear on some of the upholstery meant they were useless and he didn't want them anymore. Not exactly sound logic in my opinion but there you are... his loss, my gain.Another thing I can add to the free component list. P_20151206_150755.thumb.jpg.39967026698f204e3ce9798c4dcd4812.jpg
As you can see they're not the prettiest seats in the world but at the end of the day they're free and I think I have a plan to sort out the ugliness. I did a quick bit of research and apparently they're out of a 1990ish honda prelude so at the end of the day I can make mounts to fit these and if I want to I can fit bucket seats designed to fit a prelude if I want. Despite their looks, they are very comfortable with lumbar, tilt, and lateral support adjustment along with the bonus that they have the passenger operated tilt lever so the guys in the back seat can get out easy.
The second win for the day was a big parts haul from another of dad's many mates. There's a guy around whangarei that drives a 1100 mk1 estate as his daily and he's stashed away two mk2 estates as parts cars. After a quick chat he very generously offered any interior parts we wanted since he only wanted mechanical spares off of them. So from that I managed to score 1x back seat with full clown car spec upholsteryP_20151206_150828.thumb.jpg.af5ed95711bde45ff40426b8b9436bb1.jpgP_20151206_150810.thumb.jpg.98b686b3946c4f854937e064e07f90a3.jpg, 1x homemade purri gear knob, 1x center console, 1x gear stick bootP_20151206_150837.thumb.jpg.499da70566b4f66a8b8439d26464fb98.jpgP_20151206_150803.thumb.jpg.e1c10cf3ca99b384b6dcaac75b9d56c4.jpg
Oh and shitloads of other stuff like full seat belts, door panels, heater box, kick panels, glovebox, dash trim, steering column and wheel, and more. We made sure to bag and tag everything so we know exactly where everything came from. So definitely a couple of wins that day.
The eagle eyed among you may have noticed some holes drilled in the trans tunnel under the center console in the last post. They foreshadow the next step on the journey.
The next thing we wanted to do was get the type 9 in the hole to see how things were going to line up and how much fab work was going to be necessary. So that meant making a bloody great hole in my car!!P_20160104_193237.thumb.jpg.c4503ecbd218bd38fcc9e7a9f7725e6a.jpg
As you can see from all the holes, we carefully located all the spot welds and delicately drilled them out before gingerly hacking the firewall to pieces with a dodgy grinding disk. The seat boxes were pulled out at the same time revealing more rust holes.P_20160104_193324.thumb.jpg.43699c7f05ab3b4fc694fa2628911c91.jpg
By doing it this way the plan was to move the top of the tunnel rearward to retain the stock swages and shape. Then a simple patch was to be made to cover up the gaping hole opened up at the front of the tunnel. Simples. Also the gearbox mounts were removed in a similar fashion to be relocated to fit the type 9 at the same time.
Here we've hung the box off the hoist to put it within cooee of the right spot. The rust holes that were under the seat box are clear here as well.P_20160105_132829.thumb.jpg.39924458c825a5cca7e6909ffb435cde.jpg
Then it was a simple task of marking up the new shape and trimming the paper thin factory ford steel with tin snips.P_20160105_132833.thumb.jpg.ef284fd6ba036dc62f138de2e0746b33.jpgP_20160105_133034.thumb.jpg.b8cb1069feecfe9be3cc681ee1d9d598.jpgP_20160105_133114.thumb.jpg.833278196a3a82c0544091e4ae174191.jpg
But that's enough excitement for tonight. More tomorrow.
  • Like 6
Now was the point where it was decided that the pinto was simply too modern and complicated for what we wanted. We needed something simpler, more prehistoric. So Flintstones power it is!P_20160131_123231_SRES-min-min.thumb.jpg.61e6c45c813e835a6c7c77568ab00894.jpg
Saves a bunch of headaches worrying about complicated stuff like fuel and electrics and so forth this way.
Before we cut the floors out we lay some poster paper down on the floors and made up some templates to then be transferred to 1mm sheet steel to make up the new floor pans.P_20160105_155623.thumb.jpg.82ba9c9f22ef17b9974d28db2d398d7c.jpg
Then after my dumbass forgets to take any photos of the process, you have two floorpans with close to stock swage locations. Then it's a simple job of filling up ten billion plug welds and viola, one floor pan welded in.P_20160204_151052_SRES-min-min.thumb.jpg.45f0111e28a009334374db502715808e.jpg
You'll notice the side of the tunnel was cut out and replaced as well. This wasn't the original plan but after taking out the gearbox mounts and seat boxes it was in such a state that replacing the lot was much easier than trying to fill each hole individually. It also affords the peace of mind of knowing there's some decent gauge steel in the car rather than ford's paper mache.P_20160204_151112_SRES-min-min.thumb.jpg.e0b5f184536befa09fae162a3375cdc6.jpgP_20160204_151103_SRES-min-min.thumb.jpg.ee5c10dccba22a89d828b9e156d9dee6.jpg
A massive thanks to my dad for all this. It was a while before I had the confidence to start doing this sort of stuff myself.
Then we rolled it out of the shed (probably to get it out of the way of something or other, I forget) and took some photos of it in the sunlight. It sits a bloody long way up in the front when there's no weight in the engine bay.P_20160204_165206_SRES-min-min.thumb.jpg.756c6d3077b501f9f9fe09a24b4e3f2d.jpgP_20160204_165222_SRES-min-min.thumb.jpg.1455a96b77395d215d5e9baef9e3c24e.jpgP_20160204_165245_SRES-min-min.thumb.jpg.2800e00e87122faddcc74b7c9d0a0b21.jpgP_20160204_165256_SRES-min-min.thumb.jpg.0ee8ed5197c9fc1efbf7ef1389443dd6.jpg
Flintstones power plant on show.P_20160204_165304_SRES-min-min.thumb.jpg.08908b112cb6f7429d5e3837fa7ebaa6.jpg
I'm really digging the cheviot turbos. They look sweet in the sunlight.
Lacking a proper spot weld drill as well as much knowledge of how to properly split spot welds, I decided to attack the driver's side guard. It had some decent rust along the back bottom edge and at the A-pillar join so it needed to come off. Here is the results of my ignorance.P_20160323_075559_SRES.thumb.jpg.19f4357c4e8653dbb5ffb224e73dcb4b.jpgP_20160323_075616_SRES.thumb.jpg.0000f400e0f4ac9e9e07d4c67e027a48.jpg
Once that was split, not much really happened until I got a couple of weeks off over the school holidays.
To make the most of the time I had off we put the car on a trailer and dragged it to yet another of dad's friend's. He's a retired panel beater who kindly offered to do some more advanced panel replacement stuff that dad didn't want to do. Even more generously he was happy to let me hang around during the day and learn. So over the course of a few days he cut out the rotten driver's side sill ready to be replaced with a repro panel from palmside. He made the comment on how the shell didn't move an inch after losing the whole sill, even with no extra bracing put in. P_20160418_121940_SRES-min-min.thumb.jpg.d39ae8eaac80cffb2dc03d912d8e8040.jpgP_20160418_122048_SRES-min-min.thumb.jpg.040f9ea13786b13281fda37203373927.jpg
Once it was cut out the new panel was tacked in P_20160419_163205_SRES-min-min.thumb.jpg.5e4c9d65c07decbfa73dd039781794b1.jpgP_20160419_163220_SRES-min-min.thumb.jpg.a57520594e423c747328f5d069f7437d.jpg
The inner sill was replaced at the same time. It was all fully welded in the end but I can't find any photos.
At the same time we pulled the heater bubble off and repaired the usual rust spot with another repro panel top along with a custom bottom patch.P_20160418_122003_SRES-min-min.thumb.jpg.490e17f9a44aaece82d05f2b9d21df30.jpgP_20160419_163142_SRES-min-min.thumb.jpg.6b814c9ad7b129f0c298aba9c91faa84.jpgP_20160419_163154_SRES-min-min.thumb.jpg.9b657166747a0e710dc4e4af13daeea0.jpg
Then it was time to put it back on the trailer and haul the whole lot home.
In other news, my manifold came back!P_20160613_123153_SRES-min.thumb.jpg.fb4a9ba51a7f64fcd89989e7d68eada0.jpg
It's much shinier now than when it left. Here it is in the jig we made up to hold it in the mill in the school workshop. Not to bad for a quick 30 minute jobbie.
And this is it after starting to milling it flat. The cutter is typical school quality after being used by a bunch a 13 year olds (that is to say it's pretty fucked) so it wasn't the best finish. That said it's nothing that can't be cleaned up on a surface plate with some fine grit sand paper.
Unfortunately the mill wasn't big enough so it was put on hold for a while until I could get access to a bigger mill at a local engineering shop. So for now that's extent of the manifold story.
  • Like 6
About now I decided that since I didn't know the history of the engine I had been given or the condititon of any of the internal components I would get a second pinto that I could drop straight into the hole once everything else was ready for it.P_20160703_203028_SRES-min.thumb.jpg.05b1a124208cdfa6aaf284a47458fb7c.jpgP_20160703_204000_SRES-min.thumb.jpg.db3bcc7a0e13e6e1546acb54c1e79f0b.jpg
So here it is. $350 later I have a "running" generic stock pinto motor with almost everything I would need to get it running. The other advantage of this is that now I can throw an engine in it to get it running while I save up to pay for the machining and parts to make a really hot little 2L with a big valve ported head, possibly oversized pistons, etc etc out of the more stout 205 block pinto I was given in the first place.
It was also about now that I splurged for my birthday and bought a brand new repro grill with the FORD lettering in the center from the UK. P_20160818_082508_SRES-min.thumb.jpg.d5f949c9774ca712ab530377ad25ab0e.jpgConsidering the amount I ended up  paying for it I wasn't too happy with the quality of the finish (the silver "paint" is just very poorly cut decals) but it should come up pretty good with a lick of paint. I much prefer this style of grill but they're rare as rocking horse shit to find and the guys that do have them never want to sell so a brand new one it had to be.
Finally we're back into the fabrication work :-)
This time it was all my work. Again I didn't take many photos of the process unfortunately but the results got documented well.
Firstly I welded in a new tunnel side for the drivers side. Then I tacked in the floor pan to the new steel, and fully plugged it in. Once that was done I replaced some steel on the edges of the tunnel top to give me some more space meat to weld it back in and then did exactly that. Then it was a matter of making a covering panel for the gap opened up at the front of the tunnel and putting that in, before modifying the tunnel brace to make it fit in the more rearward position required by the longer gearbox and welding that in too. You can see the huge number of plug welds on that brace alone which explains why this was a fair bit of work all at once.P_20161002_165715.thumb.jpg.e7d432d093bd3f528421306fdf478966.jpgP_20161002_165654.thumb.jpg.f87ed0f8bcc5257769f3355778de440c.jpgP_20161002_165647.thumb.jpg.e6d47fa5231a65ada09c0610599bdcc2.jpg
At the same time I remounted the gearbox mounts in the new location (as you can see from the welds about halfway down the side of the tunnel) and fabbed some gearbox mount spacers to drop the box down the right amount to keep it all in the right spot.
Unfortunately this is the only photo I took of it but use your imagination. The square plates blank off the ends of the square tubing and the bits of tube are welded into the holes to form crush tubed for the bolts to pass through. Trust me when I say the came up pretty neat.
Continuing the floor themed fabrication work the next job was to make up some seat boxes to replace the ones that were torn out. I wanted them to do a couple of things. Firstly they needed to tie the tunnel brace to the sill as the stock boxes did, as well as fitting the honda seats as low as possible and still giving the full range of movement. Initially I made up a cardboard template before transferring it to steel. We folded the basic profile up on a big sheet metal brake at a local bus company's workshop before bringing it home and I fettled up the side profiles to fit the tunnel and inner sill as closely as possible. Doubler plates were drilled, tapped, and had captive nuts welded on before being plug welded to the inside of each box. While I was at it I made up the rear mounting posts as well but I can't find any photos of them right now. I might edit them in later on. Again, typical me, only the final product is shown. I'm leaving them loose at the moment until I can get a cert man to come and double check them to make sure they're up to scratch before I weld them in.P_20161012_171013.thumb.jpg.40aafccc62e36c8be6002af8730f3726.jpgP_20161012_171025.thumb.jpg.6ac90534986b834a9bfea27b630e53dc.jpgP_20161012_170949.thumb.jpg.d08425b7b4278152055ea31d46836554.jpgP_20161012_170917.thumb.jpg.fac4e75973a8a4335b74cb3d8ab4f816.jpg
Dad modified the pinto sump to clear the escort cross member because while an alloy RS2000 unit would be nice, the price is a bit excessive. I did some rough calculations to make sure it's close to the stock volume. FB_IMG_1468105790479.jpg.8f069a8a1aacb9062a517d7f04dfd25b.jpgFB_IMG_1468105797692.jpg.9b4a7ce0e9e2ac8265dc3fb729f8b1ee.jpgFB_IMG_1468105807884.jpg.6ce5fac8a2a79d0220e2310da17c40ad.jpg
Note the cutout to avoid the clutch cable. Not shown in the photos is the baffle added later on.
My next mini project was sorting out the twin carb linkage setup. I drew a lot of inspiration from the setup on my dad's 1600 but made a few tweaks. His is designed with the primary venturis furthest from the intake ports with the idea that when the secondaries open they have a straight shot down the thing's neck. In the interest of throttle response I've decided to instead put the primaries closest. This probably has little real world effect but I liked how it sounded. P_20161025_215527.thumb.jpg.4ec76dfcf334ad515886e800414bcaec.jpgP_20161025_215539.thumb.jpg.11d927c02fbce8e1dc4f61e6b9651202.jpg
As you can see from the photos, there is a central stainless shaft mounted by a pair of rose joints, themselves mounted to two alloy plates clamped between the carb and the manifold. Off of the rod are mounted three stainless arms. The first is connected to the standard RS2000 throttle cable. The other two are connected to what I can only describe as miniature track rod ends which themselves are connected to another set, then the final linkage onto the carb. I back of the envelope calculated the lengths of the different arms to give me full pedal travel for full butterfly travel, hopefully avoiding a super twitchy throttle like the one in my dad's car. I also added an extra return spring on the cam cover just in case.
In hindsight I want to revise the linkage with the two tie rod end things because they are both right hand threaded onto the central rod. This means I can only adjust the length of this part by one full turn relative to each other which would make balancing the two carbs damn difficult, if not impossible.
Here is a video of the linkage in action,
And here is a bonus video of milling up the carb face of the manifold. A huge thanks to Earle Tito Engineering Ltd for going the machining.
  • Like 6
Next thing I got on to was investigating the small amount of rust you could see on the bottom of the front valence panel which you can sort of see in this photo.P_20151127_152659.thumb.jpg.fdf368227fd6865670fecc95f079a675.jpg
I could see a bit where there was some bog lifting away from the rusting steel underneath. So I put a screwdriver in behind the bog and chipped it out to see how far the bog went. And went. And went. There was a bit of bog on there actually. P_20161114_075536.thumb.jpg.689fe2e03c401e92fe1017fd988312c4.jpg
That's a size 10 boot and the pile is as high as the top of it.P_20161113_155523.thumb.jpg.5f2120c04b649dc1818b3bec70e376ec.jpgP_20161113_155534.thumb.jpg.d3b623b4a4a6e98a6a93b192c1ceec71.jpgP_20161113_155541.thumb.jpg.d8b84dcf65e589e3a9907fc24b5f5b97.jpg
This is the state of what the bog was covering. The photos struggle to portray just quite how much the panel is pushed in. It was a mess.P_20161113_155449_BF.thumb.jpg.6e183a7e69a0b9e90e6eee1cb88034e2.jpg
This is some of the thicker chunks of bog that came off. Please note that they're directly end on to the camera. That is actually how thick it was. There really are some gifted "panel beaters" out there.
  • Like 9
