jono007 Posted June 1, 2017 Share Posted June 1, 2017 Hi, Just wondering if anyone knows the dimensions of the Beams 3SGE crank as I will be bringing one back with me from Aus but need to know if it will fit in my small suitcase. I have looked all over the net but can't find the dimensions? Thanks heaps, Jono Quote Link to comment Share on other sites More sharing options...
tortron Posted June 1, 2017 Share Posted June 1, 2017 http://z4.invisionfree.com/lexusaltezzaclub/ar/t10693.htm close enough? Quote Link to comment Share on other sites More sharing options...
jono007 Posted June 1, 2017 Author Share Posted June 1, 2017 Cheers for that, I had found that previous and was using the 515mm for the basis of fitting in my case. Just thought I'd see if there was anything exact out there which it seems there's not haha. Thanks again for your help, now to drag 18kgs of metal home with me.... Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 1, 2017 Share Posted June 1, 2017 I'll try to measure one for you this weekend. My guess is that the total diameter will be about 200mm and total length roughly 650mm. Quote Link to comment Share on other sites More sharing options...
jono007 Posted June 1, 2017 Author Share Posted June 1, 2017 That'd be much appreciated if you could. Thanks. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 6, 2017 Share Posted June 6, 2017 Couldn't find the crank on the weekend sorry. Found a 4AGE one though, hah. They are roughly 500 x 130 which is completely useless information. Quote Link to comment Share on other sites More sharing options...
jono007 Posted June 6, 2017 Author Share Posted June 6, 2017 Haha Gold, funny though as I did consider measuring a forged 4AGE crank I have but then was like why? Will be all good I'm sure it will fit in the carryon case. Will measure up once I'm home and post my results just cause. Thanks again. Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted June 10, 2017 Share Posted June 10, 2017 Sorry I didn't see this I have billet 1s here std Toyota are 18.5 kilos mine are 15 kilos should fit into your suit case with clothes either side ,,, if you have 25 kilo luggage Quote Link to comment Share on other sites More sharing options...
jono007 Posted June 20, 2017 Author Share Posted June 20, 2017 On 10/06/2017 at 09:27, Celica RA45 said: Sorry I didn't see this I have billet 1s here std Toyota are 18.5 kilos mine are 15 kilos should fit into your suit case with clothes either side ,,, if you have 25 kilo luggage No worries, I have 23kg allowance I think? Nothing else in the case but crank and a couple towels wrapped around it. Its a Toda 2.2L crank which I believe is a reground 5S crank which should be in the 18kg ball park? Will see tomorrow...... Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted June 20, 2017 Share Posted June 20, 2017 toda crank is a 5sfe jobby ground down to suit 3 s rods Quote Link to comment Share on other sites More sharing options...
jono007 Posted June 20, 2017 Author Share Posted June 20, 2017 2 hours ago, Celica RA45 said: toda crank is a 5sfe jobby ground down to suit 3 s rods I got the Toda pistons with it as well, as well as the rods, are the rods standard length 3S that you are aware of? I havnt pulled down my spare engine to compare yet. Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted June 20, 2017 Share Posted June 20, 2017 i dont think they would be .or they might be std but with different length rods ,did you get this from justin Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted June 20, 2017 Share Posted June 20, 2017 std 3s rods are 138mm center to center Quote Link to comment Share on other sites More sharing options...
jono007 Posted June 20, 2017 Author Share Posted June 20, 2017 Yeah I did, you know him? I got some Toda quad throttles off another guy in Aus as well. Saved on freight. Quote Link to comment Share on other sites More sharing options...
