The Difference between GL - 4 and GL - 5 gear oils
SOHC
On 20/05/2017 at 20:22, SOHC said:
This is interesting if you can be bothered reading it and is important if you have an old manual car
http://www.widman.biz/uploads/Transaxle_oil.pdf
Kind of proves why you shouldn't use GL-5 in a 2 speed diff' from the 1920's due to the brass/bronze wearing away.  Someone was saying ti would take 800 years to eat the brass but that's only if its not driven.
I had a big pissaround trying to find the right oil for my old NC MX5 6spd box, because apparently they hate GL5 as it messes up the brass syncros, but finding a proper GL4 in the right spec wasnt easy. Cant remember if i even bothered doing it.
  • 3 months later...
@GuyWithAviators
http://www.lubenz.co.nz/transmission-oil/140-transgear-4-80w90.html
http://www.lubenz.co.nz/content/22-vertex
Have not personally used their stuff but it's marketed toward the truck/fleet market. That top link is specifically a GL-4 so will be ideal for you.
Shouldn't be too pricey either. Perhaps @Dolan might have some other GL-4 alternatives through his company dealzzzz.
Another interesting thing I have been reading about is that the later transmission oils even tho they are yellow metal safe have friction modifiers that cause the old bronze syncros to slip and nor grab properly witch cuts there life in half.
