Russell builds a F50 (SOG)
My name is Russell
Suzuki Owners Group, Take One
Tried to order everything I could think of at once, hopefully more than half of it works / fits.
List for future reference / if anyone wants to do similar and for myself to order replacement parts.
  • Por15 tank sealer
  • NOS leg shield inddicator assemblies
  • BIG BLOCK! GPX 140cc Motor
  • MIKUNI - PZ30 30mm Carb
  • CDI - 8 Pin Race
  • Wiring Loom - 8 Pin
  • x2 Vesrah brake shoes VB312
  • Clutch, Brake and Throttle cable
  • Dual Layer Pod 44 x 102 15deg Angled Uni Filter
  • Domino Tommaselli Throttle
  • Petrol tubing neoprene 3/16"i.d. black (m)
  • Fuel Filter
  • x2 Brake & Clutch leavers
  • 2008/09 Hayden Paddon poster "signed . . . oh what!
  • x2 275-17 HF307 Trail tyres
  • x2 Tubes & Rim Tapes for rusty rim jobs
  • New side stand
  • Carb Manifold Intake Rotator Adapter
18033910_10159003850295725_3031347460439image hosting websitescertificity.com
Frame water blasted and ready for re assembly ish.
18056845_10159023767860725_6926890568071how to take a screenshot on a pccertificity.com
The plan is to try and retain some patina with new running gear in places required.
So far the frame is a fair bit more different than from the Honda CUB family so this might not be the simple bolt in job I expected, hence the grinder on standby. Getting the carb to fit will  the least fun! Que Rotator Adapter
If anyone speaks to the wife . . . all the above only cost a box of beer!
LETS DO THIS
  • Like 7
No probs may aswell do a little blurb that might be helpful to yourself and others.
Hang bike from Rafters with strops
18191342_10159052897800725_94228492_n.jppic hostcertificity.com
Made front and real axle centers equal height above ground level
18197396_10159052896345725_134145441_n.jphoto hosting sitescertificity.com
Check plum
18197466_10159052896095725_1236061197_n.image hosting 30 mbcertificity.com
Drill motor casing out slightly to suit 10mm bolts (I normally do this on the 125's Lifan's also)
18191234_10159052897480725_2082620172_n.free photo uploadcertificity.com
Loop some strops front and back and crank it into position.
18191355_10159052897605725_959439752_n.jupload imgcertificity.com
Just the look I was going for.
untitled.pngfree upload image
Found foot peg mounting bar with fold up pegs and side stand.
http://www.nzmotorfactory.co.nz/index.php?option=com_virtuemart&page=shop.browse&category_id=45&Itemid=1
untitled1.pngimage url
Found a tube that perfectly sleaves the standard bars giving  22mm Or 7/8", allowing the bar junk to bolt up nicely and throttle spin freely, Feels good! Took a fair bit of head scratching. Was Just about to re fabricate C90 bars to suit.
untitled2.pngjpg images
untitled3.pngimage upload no compression
Found a guy down in Nelson selling  Honda C50/70 Kickstart Lever 's which used to be difficult to find, they work well because they have an offset hook to clear the exhaust on the downward STROKE. I took a punt buying it at work without chcking the Thumpstar's spline diamater which turns out is the larger 16mm. But the wifes C90 needed a new one anyway so no loss.  Would work fine on the 125cc's I would say.
Spent agess trying different rear sprokets to match the pitbikes 428 chain, Honda's are slightly different PCD and have a larger centre so tried the AX100's being from the same family and perfect snug fit.
Little experiment. Made a flute . . .  (will wrap it with some muff stuff if it actually does whistle)
the engine end of the tube is capped with the notched plate to keep it centred
and put it down a hole
Might sound rubbish. Will have a go at making a supertrapp if it does
