PBaines 1977 Toyota Corolla KE30
pbaines
Uhh, well. two project, no worries.
I bought this off trademe a few months back, original EVERYTHING which was super cool, even have the original registration card from 1977 from Toyota Otago. Was in a family for years and years and sold the guy I got it from who had it for a few years but didn't do much with it. Came with two new front guards (taiwan made) they fit up ok too which is a bonus.
Plans. I will stick to them this time round!
-Convert to OG black interior, not a fan of the tan personally.
-Rebuild current 3K motor that's in it, or fire it up and see how it goes
-Do panel and paint myself. Learn along the way. Shell is super straight, few rusty spots as all these KE30's do but that's ok.
-Fit super cool accessories like Monsoons,  and every piece of chrome available (Which will usually be from a Hi-Deluxe KE30)
This picture is my inspiration, I am going to go with a similar deep blue also
Anyway, here is the old bomb for now
33329172124_e5c2fba5c4_o.jpg20170220-2017-02-20 17.14.42 by phillipbaines, on Flickr
A few weeks later, I had got some goodies over from Malaysia. Included, Monsoons, rear window quarter shades, door/outer window chrome edging, all the black interior panels, black U Channel moulds, 3-spoke steering wheel. Just need to buy some black carpet and wait for the dash to come over as well as the door cards
Now it'll go sit back in its hole until I drag it out to take more tan yuckness out
Discussion:
//oldschool.co.nz/index.php?/topic/56136-pbaines-1977-toyota-corolla-ke30/
  • Like 6
So I have the week off and the parents went off to Brisbane for the week, what are the chances...
I've pinched their shed for the week so I can ho into this KE30 and get it all stripped down and see how far on I can get with it.
I went to Mitre10 and bought a wire wheel for the grinder as well as a stripping disc to get me underway. I should probably have just paint stripped it, but I still would have had to use the strip disc to get the remainders off, and this is the original paint so is super thin so will come off in no time.
So i bought the car in, chucked it on stands and took the exterior panels off
Got the wire brush attachment out and cleaned this up in no time at all
Probably the worse section of rust on the entire car.
I gave it another once over
Did the other side
Got the stripper disc out and made quick work of the roof. surprising how bad the back aches doing this for a long period of time. Looks like I will have to have a skim of filler on the roof to fill in the pits from the rust
So. This is the rust I have to contend with on the car, for a KE30. This is nothing!
Front left underside.
Right roof section
Rear windscreen
i was attacking the outside of the rear left when I noticed something I wasn't expecting to be honest. Some boggy.
 Stripped it, looks like the only damage is along the ridge which is minuscule (just small pits) however the entire exposed section was bogged. strange.
Another update tomorrow when I complete more!
Discussion:
So today I got the spot weld drill bit and attacked the front cowl with it, after a bit of persuading with a coal chisel for the front and the side, and a pry bar to undo any of the spot welds on the inside of the car it all popped off pretty easy!
I think it took about 2 hours to get this off. Some of the spot welds were hard to see externally so I had to pry up the edging with the coal chisel to see between the steel and figure where the spot would be.
I will have to get this cleaned up also. Possibly even undo all of the spots for this as well.
Will get this sand blasted I think
As you can see, leaves etc have blocked up the drain holes so water has just sat in there and rusted it all up. I will have to cut this entire patch out, hoping to get a rust cut for this from OCA so will have to see how that goes. In fact I am probably going to be needing many rust cuts, however the problem is that all these KE30's suffer the exact same problems so finding good cuts may prove difficult!!
Next I ripped the entire dash out, simple job. Next I will get some dry ice and get all of the sound deadening out and start on taking the paint off the doors. I will use paint stripper for this, just to see how I get on with that as strip discs aren't cheap when you are using one a day!!
Hello daylight!!
I did some more stripping of this side. I paint strip the rest
Next time:
Sound deadening removal
Engine removal
Door stripping
Interior stripping
Enginebay stripping
European babes stripping (my girlfriend said this wasn't allowed :cry:)
Discussion:
Well, today the engine came out.
I decided to check, if in fact I did have the original motor in the car.
Yuss. Turns out I do! Fantastic. Very happy to be giving this KE a full makeover and put the original heart back into it.
Just so I remember how all of this went. The rest of the bay is pretty self explanatory
Also showcasing that, I really  should have checked if the gearbox had oil in it. Turns out it did, and my efforts of adding an ice cream container 80% through the drainage process didn't really achieve much. #It'sTheThoughtThatCounts.
And behold, the bare nude bay. Considering if I should get this entire shell bead blasted or something, just to get rid of all the rusty holes once and for all
I will be going in tomorrow to get some stripper and strip they bay, and also some dry ice so I can get rid of the sound deadening.
  • Like 6
  • 3 months later...
Started on my cuts as I have sourced all of the replacement sections that I am needing
Found a patch on the car, shame it's rusted through. the whole thing will come out
After many hours of using paint stripped which did absolutely next to nothing, i went with a wire wheel on a grinder. Will continue more next weekend after I drop the subframe out etc.
Discussion
https://oldschool.co.nz/index.php?/topic/56136-pbaines-1977-toyota-corolla-ke30/#comment-1844319
  • 3 months later...
So I started on the doors, oh man. few days work involved there, just doing small patches and also welding up the skins at the bottom of the door edges. I could have made a new lip but really, just as easy to weld the two skins together
There is always a post which is the perfect roundness!
Like a glooooooove
All doors dealt to
Once I was happy with the doors etc It was time to add some filler. Quite averagely.  but i did get it perfect in the end!
HIgh filler primer time
I need two new guards and bonnet. But fist, here is why you never rely on Taiwanese guards.
A) perfect edging.
B) Close as bro
A) good parallel alignment
B) Mr Taiwan put the RHS L piece on the LHS guard. Good work!
Discussion:
  • Haha 2
  • Confused 1
  • Sad 1
  • 2 months later...
Over Easter I decided to crank into some more work. I picked up some guards and a bonnet from Chch when I was down for Toyota Festival (what a day that was!)
I started with welding the new panels back in
Now. To rid all the rust that these had, i seam sealed all of the edges everywhere where metal met metal. No chance of this fouling between the skins now. Also painted the top of the dash. Probably premature, but. it's done.
Will have to use the Mr. Taiwan guards, there won't be any rust free factory guards in the country. So. Chop out the bits I need
The gap for this corner was on the piss so did some rearranging
The bonnet which I thought was in fair condition has obviously sat in some long grass at some point and rusted out half of it. not a biggie but would have been nice to have to do nothing to a panel for a change and just paint it...
But hey! Brand new NOS chrome front trim. How about that....
Welded on the CORRECT side L bracket, Mr. Taiwan welded on the LH L bracket onto the RH guard which is hilariously dumb.
glue'y
An error by me... forgot to drill the bonnet hinge holes.. oops. Had to get a pretty worn out dremel disc and cut a square out
Then it was time to put the cowl back on
I was annoyed at first when drilling spots out and going right through, but acutally turned out to be necessary as I put bolt and nut through to tighten the cowl in place
glue'y
Welded in the new section on here, was very holey before
primer goes on
Much better guard gap between the cowl and the guards.
Discussion:
  • Like 8
I have been busy blocking and filling for a few weekends now and finally it's starting to take shape and looks straight as ever.
Not here though....
black stuff is etch primer for when i went a bit too hard and went to the metal
I also put some filler on the join for the front cowl, because most of it was loooking pretty tatty since i unpicked it and welded it back on, thought i would make it look pretty again.
before:
After:
*a few weeks later*
More primer on, then out with the spot putty to smoothen out the spot weld dimples. most of this is hidden by the rear bumper, like the massive dent that can stay the way it is, 100% hidden
this stuff here is the absolute tits!!!
laid down one coat of high build primer on, will do two more next weekend and a final block just to check i have things in order
longchamps... yes or no
Chat
  • 4 weeks later...
Busy I have been, much sanding....
So I started trying to get my doors into shape. the lower half really is pretty deformed so it's been a mission. plus i'm still working on techniques etc as I quite frankly am a newb. In saying that, they've come out well and can finally start to get wet sanded with 320, then 600
I gave up trying with what I had after giving the above a sand, got a ruler out and applied some boggy
Tried not to go too hard (by ending up at bare metal). Once I hit the bare metal i got out a long ruler to see how straight it was, it's come up good! A quick etch and then prime and it was done..
I moved on to the front suspension side of things. crikey. the rust!!!
#Nolothane B)
On to the engine bay.
Seem sealed ALL of the edges, every seem in the engine bay is done (under the cowl I have seem sealed the inner so didn't need to do the outer side (engine bay side)
It became time:
ps: I chose a matte black colour for the front of the car. makes the grill look a bit more distinct...
Got the struts in, waiting for some rotors before I  chuck the hubs back on:
Overall quite happy, a couple of dust spots I will sort out nek-week.
Shall get onto wet sanding the entire body next weekend. probably won't end up painting anything.. but shall see
  • Like 9
