d.p.n.s Posted May 18, 2017 Author Share Posted May 18, 2017 Just went and picked up a 2nd hand cage. The 80year old man made it 20years ago and its still pretty good..its about 200mm short (not really worried about that) but all in all a good fit...even came with a cattle door ( pretty heavy so may just take it off and use mesh) good for loading the kids. 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 22, 2017 Author Share Posted May 22, 2017 on the trailer side of things i got the removable cage mounted and all it takes is to undo 4 bolts.....i even used 4 bolts the same...(i know not like me at all) on the cortina side of things........got the louvers on.... now its mint 2 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 3, 2017 Author Share Posted June 3, 2017 well ended up folding the sides by hand ....got the both on and then ran out of stone chip paint. 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 4, 2017 Author Share Posted June 4, 2017 wood floor all on and underside and axle cleaned and stone chipped. looks heaps better now. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 5, 2017 Author Share Posted June 5, 2017 painted the top half now . just wait for it to dry and put it back together this week. looks way bigger than 2.2m now. 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 20, 2017 Author Share Posted June 20, 2017 well 1st trip with the trailer after finishing it. and glad to say both car and trailer survived it....arse end of the car dropped when he dumped the logs in. 4 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 26, 2017 Author Share Posted June 26, 2017 sooooooooo i wanted some more lights as it does get pretty foggy down here and when i leave for work its before 5am. i dont really like the factory lights in the grills like this below and wanted to go more this way but the original carello lights cost chit loads and hard to find. sooooooo i found a guy in the uk that remakes the original brackets so i have a set on the way and decided to go with some hella comet 500 (in yellow cos euro) 2 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 26, 2017 Author Share Posted June 26, 2017 also changed to a mk4 grill..........much better and once the brackets are here ill get the lights on Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 29, 2017 Author Share Posted June 29, 2017 Is nice.....I like 1 Quote Link to comment Share on other sites More sharing options...
Popular Post d.p.n.s Posted July 1, 2017 Author Popular Post Share Posted July 1, 2017 wee up date. i had a 10" fan on the radiator and it was fine but once i hooked the trailer on and fulled the fucker with wood i noticed that the temp was getting higher than it had before.. so i grabbed a 16" fan as it would fit perfectly in the factory shroud but NO!!!!! well it did fit perfectly but even with moving the radiator back in closer it still hit the water pump. so i had to put it on the other side. and fuck me it blows......gets up to temp ...fan kicks in and it turns off withing a few minutes.....(just idling) and then i started on the spot light. (karl pointed out tome one day that there are dimples in the panel for mounting holes) so after drilling them out i mounted the ..............um ....mounts now all wired up and working ......even changed to the mk4 grill 13 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted July 5, 2017 Author Share Posted July 5, 2017 just a quick 1...... passed its 1st WOF in my possession 8 Quote Link to comment Share on other sites More sharing options...
Popular Post d.p.n.s Posted August 14, 2017 Author Popular Post Share Posted August 14, 2017 been gather bits here and there for a new motor build for the old girl. new belt new gaskets sierra efi dizzy (hall effect) 205 long block (cheers karl) low mount maifold ,evo turbo, falcon cpi on pinto manifold once i pull the motor down ill cheack bearings and rebuild. cheers 13 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted December 17, 2017 Author Share Posted December 17, 2017 just a wee update. still daily driving it and all the maintenance i have done is a set of plugs.. but yesterday i swapped out the 4 speed for a 5 speed... to be honest i think i prefer the 4 speed but the 5th gear will make it nice driving back and forth to work. the throw on the gear stick was like rowing a boat so i shortened up about 20-30%. all in all. very happy 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 21, 2018 Author Share Posted January 21, 2018 a wee small update on th old girl (picture less ) she flew throw her 2nd WOF in my possession... i also swapped th aftermarket hard as fuck engine mounts that shock evry thing to death out for the old factory ones in th mk3. so much better but the engine sat a wee bit lower and that in turn lifted the arse end of the gearbox and then that made the driveshaft rubber doughnut hit the tunnel.. so i spaced the gearbox crossmember down and man its so smooooooth and awesome to drive. i also swapped the heater motor out (chewed to fuck and on full tit vibrated like mad) for the mk3 motor...man the heat and silence is perfect. on a side note with the 5speed i am now getting just over 500ks of daily driving goodness to a tank of gas. so all in all still happy with it..(needs and LSD and 100 more HP) 2 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted February 3, 2018 Author Share Posted February 3, 2018 stripped down the old 205 block..standard bores ans all in all very good condition .still collecting bits here and there for the rebuild. my very good condition 2nd hand cosworth pistons arrived today..will go nicely with the eagle rods. my cosworth 2wd inlet manifold is on its way and i have a mate looking out for an oil pump pick and bore squirters from an rs500 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted July 2, 2018 Author Share Posted July 2, 2018 Couple of povs from yesterday's kustom rodders breakfast. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 1, 2019 Author Share Posted June 1, 2019 well after over 2 years of ownership and passing every wof so far as well as never really letting me down apart from the few times it hasn't wanted to start. there are a few issues with the old girl...after last years hamner meet it picked up a vibration in the drive train.(still looking into that. the motor starts and runs well but it blowing smoke (valve guides are stuffed .(working on that now) so i do have a 205 pinto motor in bits so im going to rebuild that and to factory spec ...no interested in huge cams and twin side drafts ..im happy with the motor in my cortina now so just want the same....its good on gas and can pull a trailer with another car on it fine. so i started cleaning up the old 205 pistons. 8 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 15, 2019 Author Share Posted June 15, 2019 i got some of the years and a wee bit of outside life followed by neglect cleaned off the block. 6 Quote Link to comment Share on other sites More sharing options...
Popular Post d.p.n.s Posted January 7, 2020 Author Popular Post Share Posted January 7, 2020 well i havnt build the new motor yet .....because i have other shit to play with.....but the old pinhoe has been getting worse......blows shit loads of smoke and sounds like a diesel... the mk3 parts car i bought had a mighty pinthoe in it... so i pulled it out pulled the clutch ,flywheel,pressure plate,inlet and carb , thermostat and water pump of mine and slapped it on to the other one.... reason being mine ran and i had done them last year. some new plugs and oil.....and man it starts first pop.....no smoke.....and so quiet . old pinthoe other old pinthoe blooody good 17 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted January 21, 2020 Author Share Posted January 21, 2020 WOF yeaterday...again another clean sheet..so all leagal for anothe 6 months. when i swapped motors i also swapped the 4 speed back in...( live in chch..fuck all motorways...flat....my work school home round trip is 32ks) and i prefer it to the 5 speed. also put a quick shifter in and it makes it heaps better. almost had ghe old gjrl 3 years now and love it...second longest ive owned a car. lol. 9 Quote Link to comment Share on other sites More sharing options...
